TC35i GSM With PIC 16F690 help
Results 1 to 34 of 34
    May 2008
    Italy
    baud con 84 ' baud rate = 9600 Inverted
    Rx var Portb.7 ' Declaring rx pin
    Tx var Portb.5 ' Declaring tx pin
    Change your code as per the above, then it should work.
    Edited:
    Remember to allow the modem to settle after powerup, before start serial communication (See modem led blink)
    Al.
    Exclamation
    Quote Originally Posted by aratti View Post
    Al.
    No Luck still. In the datasheet, portb.5 is Rx & portb.7 is Tx! Why you advised to mark it the other way. Though it's still not working.
    Also 9600 Inverted is NOT 84 (just looked into the PBP manual) it is 16468
    Program is the same as above (With your modifications) i.e. Baud 84 & ports interchanged.
  1. Want to learn GSM & PIC programming
    By financecatalyst in forum GSM
    Last Post: - 25th February 2014, 10:22
  2. GSM With PIC?
    By financecatalyst in forum General
    Last Post: - 20th September 2009, 00:12
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 04:59
  4. gsm card reader using pic
    By ninebarmaximus in forum General
    Last Post: - 6th December 2005, 19:08
