PID-filter routine (2nd try).
Results 1 to 40 of 132
Threaded View
  1. #9
    Aug 2009
    Default Hi Henrik
    I have many trys to solve my problem but fail.Actually i want to control GAS engine speed.I am using AGB130 LINEAR ELECTRIC ACTUATOR to drive BUTTERFLY VALVE.I am using MAGNETIC PICKUP UNIT located on flyweel to sense engine speed.After F/V conversion i have 0-5000Hz to 0-5V.
    Problem is that ACTUATOR drive only forward direction through given voltage
    and reverse direction through SPRING located inside.
    ACTUATOR always needed some voltage to remain in a position to maintain speed.But INCPID routine gives 0 output when no error found.
    I am giving some examples in atachements which will help to identify problem.
    Best regards
    IFTIKHAR AHMAD
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 20:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 12:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
