OK, so what does it do if the setpoint is 51 then?The Henrik PID rutine work good but only when position and setpoint is max +/-50 !
I see you're using On Interrupt and it seems you're using TMR0 as the source for the interrupt. It would be good if you could comment that section a bit so we don't have to read thru the datasheet in order to figure out what you're trying to do.
If I haven't missed anything you're running TMR0 in 8bit mode, clocked from the internal clock @20/4=5Mhz, prescaler selection is set to 1:2 which means the timer is clocked at 2.5Mhz, overflowing and generating interrupts at 9765.625Hz. There's no need to run the PID-loop at that speed, generally 1000Hz is good enough for motor control.
The Pause 10 statement needs to go away, and the LCDOut statements will likely mess with the timing as well. Read up on how On Interrupt works in the PBP manual. I highly recomend you look up Darrels Instant Interrupt routines as they don't suffer from the things On Interrupt does.
What do you mean byIt's really hard to understnad what you mean..... A deadband where anything within 25% of the setpoint is good enough or a following error trip and when the error is bigger than a set amount?and realy how make to motor clip +/- when position = setposition in some range about +/- 25% as break in position
I've just received my copy of v2.60 so I can start using 32bit variables. I'm having a bt of a problem getting it going though. On top of that I fried my servo development board by connecting 24V to the 5V input so I need to get that sorted....
