PID-filter routine (2nd try).
Results 1 to 40 of 132
    Hello,
    I thought I explained that in post #16 above. I'll simply quote myself:
    Regarding the pots, you can set the PID gains in any number system you like. The reason I show it in hex is that it is easier IMO. You can simply do pid_Kp = myADResult if you like.
    1023 in decimal is the same as $03FF which, in the PID filter, is treated as 3.996 basically. See, 03 is the number on the left side of the decimalpoint and FF is on the right side. FF represents 1/256*255 or 0.996. If you'd feed it 102 from the ADConverter it would be the same as $0066 or a gain of 0.258.
    If you need more gain than 1023 then simply multiply your ADResult, pid_KP=myADResult*2, now you get a gain of 0-2046 or $0000-$07FE or 0.0-7.992
    I don't really know how to explain it in any other way but let me know if doesn't make sense and I'll try, or perhaps someone else can attack it from another angle.
    Wink
    Hi, Hadienggggggg
    At full speed refrence it get exact speed never overshoot.I am using same PID gains used in original file.I think i must change the GAIN value to overcome this problem
    EACH system has its own set of parameters ( Kp, Ki, Kd ) and you are the one and only one who can find them ...
    NOW, just Google around for the " Ziegler and Nichols method " ... sure it will help you !
    FURTHER ... you can disable The Ki and Kd action at startup and engage then for a maximum error of ???, you can use retrieve tables for Kp,Ki,Kd as a function of the running point, you can program a rampup for engine start ...
    But that is VERY typical to YOUR project ... and far out from Henrik's project shown here ...
    BTW ... MERCI Henrik ...
    May 2007
    Republic Serbia
    Default My probe with problem of use incPID.pbp
    The QEI reading work good with count for position from 0-1000.
    The PPWM give good voltage and signal too from 0 - 1024 at 20KHz.
    The Henrik PID rutine work good but only when position and setpoint is max +/-50 !
    and realy how make to motor clip +/- when position = setposition in some range about +/- 25% as break in position.
    My output driver have next logic :
    with PWM 512 motor STOP
    0<--------512----->1024
    left <---- stop-----> right
    fast slow stop slow fast
    Here is my debug program:
    '                 Definicije PIC-a  18F4431                     *
        DEFINE OSC 20
        include "incPID.pbp"
    '                        LCD DEFINE LCD 4X20 chr             *
        DEFINE LCD_DREG PORTD
        DEFINE LCD_DBIT 4
        DEFINE LCD_RSREG PORTC
        DEFINE LCD_RSBIT 0
        DEFINE LCD_EREG PORTC
        DEFINE LCD_EBIT 1
        DEFINE LCD_BITS 4
        DEFINE LCD_LINES 4
        DEFINE LCD_COMMANDUS 2000
        DEFINE LCD_DATAUS 50
    '                          Definicije Portova                   *
        ADCON0=0
        ANSEL0=0
        TRISB = %00000000
        PortA = 0
        PortB = 0
        PortC = 0
        PortD = 0
        PortC.3 = 1
    '                          Definicije  PPWM                     *
        DTCON = 0
        PTCON0 = %00000000
        PTCON1 = %10000000
        PTPERL=$FF
        PTPERH=$00
        PWMCON0 = %00100000
        PWMCON1 = 1
        OVDCOND = %11111111
    '                          Definicije QEI encodera              *
        'QEICON = %10011000
        'DFLTCON = %00111000
        'MAXCNTL = %11001111
        'MAXCNTH = %00000111
        QEICON=%10001000
        DFLTCON = %00111000
        MAXCNTL = %11101000
        MAXCNTH = %00000011
        PosLow VAR BYTE
        PosHigh VAR BYTE
        PosTemp VAR BYTE
        Position VAR WORD
        POSCNTL = 0
        POSCNTH = 0
    '                          Definicije  TMR0                     *
        T0CON = %11001000
        INTCON.5 = 1
        INTCON.1 = 0
        INTCON.7 = 1
        INTCON.4 = 0
        INTCON.3 = 0
        INTCON.2 = 0
        INTCON2.2 = 1
        RCON.7 = 1
        TMR0L =254
    '                          Definicije PID filtera               *
        x var word
        y var word
        ADValue VAR word                           '<---This is your variable.
        Setpoint VAR WORD                          '<---This is your variable.
        Direction var bit                          '<---Direction bit to motor driver
        pid_Kp = $0700                             'Set Kp to 7.0
        pid_Ki = $0080                             'Set Ki to 0.5
        pid_Kd = $0225                             'Set Kd to 2.14
        pid_Ti = 8                                 'Update I-term every 8th call to PID
        pid_I_Clamp = 100                          'Clamp I-term to max ±100
        pid_Out_Clamp = 511                        'Clamp the final output to ±511
        x = 0
        y = 0
        setpoint = 100
        pause 250
        lcdout $fe,1
    '                          Osnovna petlja                       *
    on interrupt goto PIDcalc
         loop:
         if portc.3 = 1 then setpoint = setpoint + 1
         if setpoint > 1000 then setpoint = 0
         LCDOUT $fe,128,"POSITION = ",dec position
         LCDOUT $fe,192,"SETPOINT = ",dec setpoint
         LCDOUT $fe,148,"PID = ",dec pid_out
         LCDOUT $fe,212,"PWM = ",dec y
         pause 10
         lcdout $fe,1
         goto loop
         disable
    PIDcalc:
         INTCON.1 = 0
         if INTCON.2 = 1 then
         PosHigh = POSCNTH
         PosLow = POSCNTL
         PosTemp = POSCNTL
         If PosLow - PosTemp = 0 then Goto Done
         PosHigh = POSCNTH
         PosLow = POSCNTL
    Done:
         Position = POSHIGH * 256 + PosLow
         advalue = position
         pid_Error = Setpoint - ADValue
         Gosub PID
         Direction = pid_Out.15
         pid_out = ABS pid_Out
         x = (512 - pid_Out) + 512
         select case direction
         case 1
         y = pid_Out
         case 0
         y = x
         end select
         PDC0L = y.LowByte
         PDC0H = y.HighByte
         INTCON.2 = 0
         resume
         enable
    If any help pls.
    Regards Robert
    OK, so what does it do if the setpoint is 51 then?
    I see you're using On Interrupt and it seems you're using TMR0 as the source for the interrupt. It would be good if you could comment that section a bit so we don't have to read thru the datasheet in order to figure out what you're trying to do.
    If I haven't missed anything you're running TMR0 in 8bit mode, clocked from the internal clock @20/4=5Mhz, prescaler selection is set to 1:2 which means the timer is clocked at 2.5Mhz, overflowing and generating interrupts at 9765.625Hz. There's no need to run the PID-loop at that speed, generally 1000Hz is good enough for motor control.
    The Pause 10 statement needs to go away, and the LCDOut statements will likely mess with the timing as well. Read up on how On Interrupt works in the PBP manual. I highly recomend you look up Darrels Instant Interrupt routines as they don't suffer from the things On Interrupt does.
    What do you mean by
    It's really hard to understnad what you mean..... A deadband where anything within 25% of the setpoint is good enough or a following error trip and when the error is bigger than a set amount?
    I've just received my copy of v2.60 so I can start using 32bit variables. I'm having a bt of a problem getting it going though. On top of that I fried my servo development board by connecting 24V to the 5V input so I need to get that sorted....
    May 2007
    Republic Serbia
    Unhappy
    here is what I rewrite in incPID
    'Calculate the total drive.
    pid_Out = pid_P + pid_I + pid_D         'Calculate total drive....
     pid_Sign = pid_Out.15                   'Save Sign
     pid_Out = ABS pid_Out                   'Convert from two's comp. to abs.
    'if  pid_Out >= pid_Out_Clamp then        'Output is saturated...
    if  pid_Out >= 640 then
        pid_Status_Out_Sat = 1              'set status bit and...
         pid_out = pid_Out_Clamp             'clamp output.
    Endif
    'If pid_Sign then pid_out = -pid_out     'Re-apply sign.
    RETURN                                  'And return to sender.
    SkipPID:
    now the PID work close to good , ABS pid_error is in range close to 511 +/- 100 when I probe to personal move shaft of motor.
    Becous my motor have gear 6.25:1 my variable ( y as LONG) go from 0-6250 for one full turn of shaft.Motor must go 6.25 * 1000.
    QEI is setup for one turn of motor shaft go 0-1000.
    It is not full good but it is close to be PID :-(
    PBP code :
        DEFINE OSC 20
    '                         RS 232 HSEROUT 19200 kbps             *
        DEFINE LCD_DBIT 4
        DEFINE LCD_RSBIT 0
        DEFINE LCD_EBIT 1
        DEFINE LCD_BITS 4
        DEFINE LCD_LINES 4
        ADCON0=0
        ANSEL0=0
        TRISB = %00000000
        PortA = 0
        PortB = 0
        PortC = 0
        PortD = 0
        PortC.3 = 1
    '                          Definicije  PPWM                     *
        DTCON = 0
        PTCON0 = %00000000
        PTCON1 = %10000000
        PTPERL=$FF
        PTPERH=$00
        PWMCON0 = %00100000
        PWMCON1 = 1
        OVDCOND = %11111111
        QEICON=%10001000
        DFLTCON = %00111000                ' enable error filter for all capture inputs
        MAXCNTL = %11101000               'low set for maxcnt of 12500 becouse have gear 6.25:1
        MAXCNTH = %00000011                'hig set for maxcnt of 12500 becouse have gear 6.25:1
        PosLow VAR BYTE
        PosHigh VAR BYTE
        PosTemp VAR BYTE
        Position VAR WORD
        POSCNTL = 0                        ' clear lowbyte of counter for start
        POSCNTH = 0                        ' clear highbyte of counter for start
    '                          Definicije  TMR0                     *
        T0CON = %11001111
        INTCON.5 = 1
        INTCON.1 = 0
        INTCON.7 = 1
        INTCON.4 = 0
        INTCON.3 = 0
        INTCON.2 = 0
        INTCON2.2 = 1
        RCON.7 = 1
        TMR0L =237       ' 8bit ,1:256 divider ,237 preset = 1000HZ at 20MHz clk
        s var word
        f var word
        y var long                         'Total pulse count storage variable 32bit
        x var byte                         'Number of full shaft rotation of 360'
        z var BIT                          'Actual bit if any move of shaft to any direction
        h var BIT                          'direction bit 0 for left , 1 for right turn of encoder
        s = 0
        f = 0
        z = 0
        x = 0
        y = 0
        h = 0
        PIR3.2 = 0
        setpoint = 0
        pause 250
        lcdout $fe,1
    '                          Osnovna petlja                       *
         loop:
         if setpoint > 6250 then setpoint = 0
         LCDOUT $fe,128,"POSITION = ",dec y
         LCDOUT $fe,212,"PWM = ",dec f," PE = ",dec ABS pid_error
         LCDOUT $fe,128,"POSITION =     "     'clear line without use $fe,1
         LCDOUT $fe,192,"SETPOINT =     "     'clear line without use $fe,1
         goto loop
         disable
    PIDcalc:
         INTCON.1 = 0
         z = 0
         PosHigh = POSCNTH                           'Get high byte of counter
         PosLow = POSCNTL                            'Get low byte of counter
         PosTemp = POSCNTL                           'Get low byte again
         If PosLow - PosTemp = 0 then Goto Done      'Compare, if equal we're done.
         PosHigh = POSCNTH                           'If not, get values again.
         PosLow = POSCNTL
         z = 1
    Done:
         Position = POSHIGH * 256 + PosLow           'Put high and lowbyte together.
         h = QEICON.5                                'QEICON.5 for right = 1 for left = 0
         if PIR3.2 = 1 and h =1 then x = x+ 1
         if x <> 0 and PIR3.2 = 1 and h =0 then x = x- 1
         PIR3.2 = 0                                  'PIR3.2 maxcount transition down or up was detected
         h = 0
         y =  (1000 * x) + position                    ' increment  total counter
         if z = 1 and h = 0 then y = y -(1000-position) ' dectement  total counter
         if y > 6250 then
         x = 0
         advalue = y
         gosub PID
         s = (512 - pid_Out) + 512
         case 0
         f = pid_Out
         case 1
         f = s
         end select
         PDC0L = f.LowByte
         PDC0H = f.HighByte
         INTCON.2 = 0
         resume
         enable
    Hi Robert,
    I'm sorry but I'm having a hard time understanding you. I like to help you but it's just hard when you don't even answer my questions. Now you say it's close to being PID? What exactly is it that doesn't work?
    If the motor isn't "stiff" enough you need to tune the PID parameters, I see you have Kp, Ki & Kd exactly as in my example code - which is just that - an example. You need to change them to suit your application.
    Also, you could as well changed your code to read pid_Out_Clamp = 640 instead of hardcoding 640 into the incPID routine. In any case if you only have 10bits of PWM resolution why allow the output to swing to +/-640 which is 11bits?
    Another thing I notice is that you preset TMR 0 with the value 237, but you do that only at the beginning of the program, so it will go from 237->256, cause an interrupt, then it will start from 0 again. With the pescaler at 1:256 that will be an interrupt rate of 38Hz which might be a bit slow. You need to preset TMR0 again in your ISR.
    You can change this:
    advalue = y
    To simply read
    pid_Error = Setpoint - y
    It won't work any better but a little faster and it'll save you a byte or two ;-)
    And, try removing the LCDOut statements as a test and see what impact that has on it. Do you have an oscilloscope? Connect it to a pin, set the pin high the first thing you do in the ISR and low again before returning - then you can see if you have the correct interrupt frequency.
    May 2007
    Republic Serbia
    ok in UHU or any other PID control if POSITION= SETPOINT motor must clip +/- for to make break in position.
    when you set SETPOINT increment +1 or +XXX then PID must move motor in that direction and when MOTOR come to SETPOINT PID must again clip motor +/- in new POSITION becous POSITION is again = SETPOINT.
    If you probe to mechanic move MOTOR SHAFT from locked position PID rutine must give reaction to back motor to lock POSITION.
    Your PID control work good maybe with L2XX motor driver chip but with real output driver like HP UHU output stage NOT work.
    In uhu sistem you have two pins on output stage.One for motor enable / disable (logic 1 enable , logic 0 disable.That is use for motor protect with current detector via resistor in DRAIN of output MOSFETS.
    Second pin is in same time PWM drive / direction.
    When PWM on these pin is 50/50% that is 512 on 10bit then motor is in stop condition.When on these pin come PWM from 512-0 you have movement of motor from slow 511 to full spid PWM close 10.And when you go from 513 to 1024 you have slow to full speed of motor at close 1014.
    My motor have gear 6.25 motor full turn for one shaft full turn.That mean I must use wariable for position storage from 0 - 6250 which represent full range for one full turn of output gear shaft.
    When I use your PID rutine it break motor to go from lock position to minus CCW and it give PWM to motor 511 , 510,...492...400 and move motor CW to lock dead point.But when i move output shaft to CW position your PID giwe PWM 511 and normaly that must be to give 513,515....600 to mowe motor in CCW to motor come to lock point.That is becouse in your position is :
         pid_out = pid_Out_Clamp '  pid_Out_Clamp = 511
    Endif
    SkipPID:
    Ok and your suggestions are good but I was spend 10..hours and my head is like baloon...sorry.
    Regards Robert
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 19:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 17:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 11:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 21:55
