I apologize for the delay. I have a spinal cord injury which incapacitates me when it acts up and it's been acting up for several days. What follows is revised slightly from the earlier code. I have not tested this with a terminal program (right now I'm working with Linux and do not have a terminal program handy) but I have looked at the GPIO.2 output with a 'scope and it appears to be a valid RS232 signal. Here's the transmit code:and here is the receiver code:Code:'-----PIC12F629----- ' Sends 2 bytes + their bitwise complements using the NEC protocol ' repeats every 15 seconds @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF DEFINE OSCCAL_1K 1 RF VAR byte[4] Copies VAR byte 'RF copies c VAR byte 'loop index (RF copies) b VAR byte 'loop index (RF[b]) i VAR byte 'bit index wb VAR byte 'work byte CMCON = 7 Copies = 4 'Put data in RF[0] & RF[2] & complement in RF[1] & RF[3] SendRF: RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2] Low GPIO.2 For c=1 To Copies PulsOut GPIO.2, 880 '8.8mS pulse PauseUs 4400 '4.4mS space For b=0 To 3 wb=RF[b] For i=0 To 7 'LSB first PulsOut GPIO.2, 50 '0.5mS pulse If wb.0=1 Then PauseUs 1500 '1.5mS space Else PauseUs 500 '0.5mS space EndIf wb=wb>>1 Next Next PulsOut GPIO.2, 50 '0.5mS pulse Pause 40: '40mS GAP Next Pause 15000 '15 SEC DELAY GoTo SendRF EndCode:'12F629 @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF DEFINE PULSIN_MAX 968 '>968 RETURNS 0 DEFINE DEBUG_REG GPIO DEFINE DEBUG_BIT 2 'GPIO.2 DEFINE DEBUG_MODE 1 'Inverted DEFINE DEBUG_BAUD 9600 DEFINE OSCCAL_1K 1 RF VAR byte[4] space VAR byte i VAR byte stx VAR word 'start of transmission CMCON = 7 'comparators off Debug "RF NEC PROTOCOL" init: RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0:i=0 PulsIn GPIO.1, 1, stx If (stx<792) Then init 'debug #stx While GPIO.1=0:Wend 'wait pulse Repeat PulsIn GPIO.1, 0, space If ((space<40) Or (space>180)) Then init If (space>75) Then RF.0(i)=1 'set bit EndIf i=i+1 Until (i>31) If (RF[0]+RF[1]<$FF) Then init 'corrupt If (RF[2]+RF[3]<$FF) Then init 'corrupt RF[1]=RF[0] REV 8 RF[3]=RF[2] REV 8 Debug RF[1],32,RF[3] GoTo init End
