Using Linx RF modules ?
Results 1 to 21 of 21
    Dec 2005
    I apologize for the delay. I have a spinal cord injury which incapacitates me when it acts up and it's been acting up for several days. What follows is revised slightly from the earlier code. I have not tested this with a terminal program (right now I'm working with Linux and do not have a terminal program handy) but I have looked at the GPIO.2 output with a 'scope and it appears to be a valid RS232 signal. Here's the transmit code:
    '-----PIC12F629-----
    ' Sends 2 bytes + their bitwise complements using the NEC protocol
    ' repeats every 15 seconds
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE OSCCAL_1K 1
    RF 	VAR	byte[4]
    Copies 	VAR	byte			'RF copies
    c	VAR	byte			'loop index (RF copies)
    b	VAR	byte			'loop index (RF[b])
    i	VAR	byte			'bit index
    wb	VAR	byte                    'work byte
            CMCON = 7
            Copies = 4
            'Put data in RF[0] & RF[2] & complement in RF[1] & RF[3]
    SendRF:	RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2]
    	Low GPIO.2
    	For c=1 To Copies
    	  PulsOut GPIO.2, 880           '8.8mS pulse
              PauseUs 4400                  '4.4mS space
    	  For b=0 To 3
                wb=RF[b]
    	    For i=0 To 7                'LSB first
    	      PulsOut GPIO.2, 50        '0.5mS pulse
    	      If wb.0=1 Then
    	        PauseUs 1500            '1.5mS space
    	      Else
    		PauseUs 500             '0.5mS space
    	      EndIf
    	      wb=wb>>1
    	    Next
    	  Next
    	  Pause 40:                     '40mS GAP
    	Next
    	Pause 15000                     '15 SEC DELAY
    	GoTo SendRF
    and here is the receiver code:
    '12F629
    DEFINE PULSIN_MAX 968				'>968 RETURNS 0
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 2				'GPIO.2
    DEFINE DEBUG_MODE 1 				'Inverted
    DEFINE DEBUG_BAUD 9600
    DEFINE OSCCAL_1K 1
    RF      VAR     byte[4]
    space   VAR     byte
    i       VAR     byte
    stx     VAR     word            	'start of transmission
            CMCON = 7                   'comparators off
            Debug "RF NEC PROTOCOL"
    init:   RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0:i=0
            PulsIn GPIO.1, 1, stx
            If (stx<792) Then init
            'debug #stx
            While GPIO.1=0:Wend			'wait pulse
            Repeat
              PulsIn GPIO.1, 0, space
              If ((space<40) Or (space>180)) Then init
              If (space>75) Then
                RF.0(i)=1				'set bit
              EndIf
              i=i+1
            Until (i>31)
            If (RF[0]+RF[1]<$FF) Then init		'corrupt
            If (RF[2]+RF[3]<$FF) Then init		'corrupt
            RF[1]=RF[0] REV 8
            RF[3]=RF[2] REV 8
            Debug RF[1],32,RF[3]
            GoTo init
    Mar 2004
    Hi Dave,
    I'm sorry to hear about your spinal chord injury ! I know a little about that personally also, unfortunately.
    Thanks for posting the code re-done, in the meantime I went ahead and ordered some encode/decode chips from Rentron and they work excellent. I am extremely impressed by the range and reliability of this combination of Linx modules and these chips.
    I did get a machine "status system" set up with the TX/encoder mounted in a small project box with a real whip antenna mounted on the top of my milling machine. When a section of the machine moves to a specific location, a button is pressed and that activates a 12F675 that turns on the TX and it transmits for .5 sec. then turns off for .3 sec., it does this 15 times with a "for/next" routine then goes to sleep until next time.
    The receiver is in a very small project box that resembles a pager with the option of either a beep or flashing an LED. This tells me when the machine is ready for a tool change.
    I'll give your new code a try soon, I want to have more status reports for other components of the machine sent to a receiver with an LCD display.
    Thanks for the help and hope you're doing well now.
    Dec 2005
    Sam,
    I've added a more generic RF Receiver example to the Code Examples forum.
  1. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 18:28
  2. Linx RXM-900-HP3 Rf Modules
    By Steve_88 in forum Off Topic
    Last Post: - 3rd June 2008, 15:58
  3. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 14:54
  4. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 20:58
  5. Wireless comms with Linx LR modules
    By telemark in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 01:58
