Using Linx RF modules ?
Results 1 to 21 of 21
    Mar 2004
    Right, status reporting is all I'm wanting to achieve with this. I do prefer to do it from scratch, I just referenced that transmitter as an example. 8 lines will be more than enough for me, 4 will will actually do just fine.
    So let's say I have the Linx TX unit and I only want it to report one single button closure on the machine to the receiver 30 feet away through one wall, and I'd like to keep it as simple as possible until I start to get a hold on this as I learn pretty fast once I get one basic thing working and can experiment from there. To keep it simple, lets forget about the LCD and just light an LED for now.
    How would you recommend I do this ?
    Much thanks.
    Dec 2005
    I would use the transmitter & receiver code shown in the first two sections atIt uses the same protocol that X-10 has used successfully for 30 years. It can handle up to 256² codes and has built-in error detection.
    Mar 2004
    That looks great, I will study it (more) and give it a try.
    Thanks for all your help Dave !
    Sam
    Mar 2004
    Dave,
    I've loaded your TX code into one 12F675 and connected to the Linx TX and it is transmitting data. ( I changed the interval from 15 seconds to 1.5 seconds)
    I then loaded your RX code as seen below into another 12F675 and I'm not getting anything out of GPIO.2. I connected a LED to the data out of the receiver and it does flash in sync with the TX data going out.
    I connect GPIO.2 of the RX PIC to Hyperterminal set at 8N1, 9600 and get nothing at all and I connected an LED to GPIO.2 and nothing there either.
    Shouldn't I be getting something on the RX PIC ?
    '==============================RECEIVER============================
    '-----PIC12F675-----
    'USE PIC12F675 if you need to measure linear output (e.g. to tune)
    'Receives 32 bits of NEC protocol RF with initial lead-in of 8.8mS
    'outputs received codes via RS232 @ 9600bps on GPIO.2
    '12F675
    _CONFIG
    @ DEVICE PIC12F675
    _NOCLKOUT
    _WDT_ON
    _PWRTE_ON
    _MCLRE_OFF
    _BODEN_ON
    INCLUDE "modedefs.bas"
    DEFINE PULSIN_MAX 968				'>968 RETURNS 0
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 2 				'GPIO.2
    DEFINE DEBUG_MODE 1 				'Inverted
    DEFINE DEBUG_BAUD 9600
    DEFINE OSCCAL_1K 1
    RF      VAR     byte[4]
    space   VAR     byte
    i       VAR     byte
    bits	VAR	byte
    stx  	VAR     word            		'start of transmission
            CMCON = 7                       	'comparators off
    init:	RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0
    	bits=0:i=0
    	PulsIn GPIO.1, 1, stx
    	If (stx<792) Then init
            While GPIO.1=0:Wend			'wait pulse
            'use SerIn here instead of Repeat loop & $FF tests
            Repeat
              PulsIn GPIO.1, 0, space
              If (space<40) Or (space>175) Then init
              If (space>75) Then
                RF.0(i)=1				'set bit
              EndIf
              i=i+1
            Until (i>31)
    	If RF[0]+RF[1]<>$FF Then init
    	If RF[2]+RF[3]<>$FF Then init
            For i = 0 to 3
      	  Debug (RF[i] REV 8)
            Next
            GoTo init
    Dec 2005
    Give me a day or two to finish something else and dig out my PIC hardware and I'll try to run this down.
    Dec 2005
    I apologize for the delay. I have a spinal cord injury which incapacitates me when it acts up and it's been acting up for several days. What follows is revised slightly from the earlier code. I have not tested this with a terminal program (right now I'm working with Linux and do not have a terminal program handy) but I have looked at the GPIO.2 output with a 'scope and it appears to be a valid RS232 signal. Here's the transmit code:
    '-----PIC12F629-----
    ' Sends 2 bytes + their bitwise complements using the NEC protocol
    ' repeats every 15 seconds
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE OSCCAL_1K 1
    RF 	VAR	byte[4]
    Copies 	VAR	byte			'RF copies
    c	VAR	byte			'loop index (RF copies)
    b	VAR	byte			'loop index (RF[b])
    i	VAR	byte			'bit index
    wb	VAR	byte                    'work byte
            CMCON = 7
            Copies = 4
            'Put data in RF[0] & RF[2] & complement in RF[1] & RF[3]
    SendRF:	RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2]
    	Low GPIO.2
    	For c=1 To Copies
    	  PulsOut GPIO.2, 880           '8.8mS pulse
              PauseUs 4400                  '4.4mS space
    	  For b=0 To 3
                wb=RF[b]
    	    For i=0 To 7                'LSB first
    	      PulsOut GPIO.2, 50        '0.5mS pulse
    	      If wb.0=1 Then
    	        PauseUs 1500            '1.5mS space
    	      Else
    		PauseUs 500             '0.5mS space
    	      EndIf
    	      wb=wb>>1
    	    Next
    	  Next
    	  Pause 40:                     '40mS GAP
    	Next
    	Pause 15000                     '15 SEC DELAY
    	GoTo SendRF
    and here is the receiver code:
    '12F629
    DEFINE OSCCAL_1K 1
    RF      VAR     byte[4]
    space   VAR     byte
    i       VAR     byte
            Debug "RF NEC PROTOCOL"
    init:   RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0:i=0
            'debug #stx
            Repeat
              If ((space<40) Or (space>180)) Then init
              If (space>75) Then
                RF.0(i)=1				'set bit
              EndIf
              i=i+1
            Until (i>31)
            If (RF[0]+RF[1]<$FF) Then init		'corrupt
            If (RF[2]+RF[3]<$FF) Then init		'corrupt
            RF[1]=RF[0] REV 8
            RF[3]=RF[2] REV 8
            Debug RF[1],32,RF[3]
            GoTo init
    Mar 2004
    Hi Dave,
    I'm sorry to hear about your spinal chord injury ! I know a little about that personally also, unfortunately.
    Thanks for posting the code re-done, in the meantime I went ahead and ordered some encode/decode chips from Rentron and they work excellent. I am extremely impressed by the range and reliability of this combination of Linx modules and these chips.
    I did get a machine "status system" set up with the TX/encoder mounted in a small project box with a real whip antenna mounted on the top of my milling machine. When a section of the machine moves to a specific location, a button is pressed and that activates a 12F675 that turns on the TX and it transmits for .5 sec. then turns off for .3 sec., it does this 15 times with a "for/next" routine then goes to sleep until next time.
    The receiver is in a very small project box that resembles a pager with the option of either a beep or flashing an LED. This tells me when the machine is ready for a tool change.
    I'll give your new code a try soon, I want to have more status reports for other components of the machine sent to a receiver with an LCD display.
    Thanks for the help and hope you're doing well now.
  1. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 19:28
  2. Linx RXM-900-HP3 Rf Modules
    By Steve_88 in forum Off Topic
    Last Post: - 3rd June 2008, 16:58
  3. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  4. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  5. Wireless comms with Linx LR modules
    By telemark in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 02:58
