... the ones that have been programming for fun since an early age and know a few languages...
As for atitude, as i allready said, i'm considerd a pro or expert or guru in various other forums and i'd be ashamed of myself if i answerd a newby's question like that...
Ioannis, thank you, direct answer saves time...Originally Posted by Ioannis
I'd actually ruled out using a resister type voltage devider for the reason that it draws curent from the source your measuring... I had thaught of an opamp or another type of amplifier...
What i'm intensly looking at and trying to resolve is a little problem i seem to have with the data coming out of both hardware and software comm ports in oshonsoft's PIC simulator IDE... dispite having Baud, stop bit and parity correct I regularly get glifs coming out of the ports... but the two ports have gilfs in diferent places... and the software port reciever is reporting stop bit errors????? weird... must be a config error somewhere, thinking about it, I wonder if stop bit/parity is set to none if pic's allow it... meh, i'f sure it's a conf error, i'll find it...
Thanks to...
Ioannis & Dave
Also, I think the PBP way of handling interupts is stupid... you should be allowed to write interupt handlers in PB without PBP inserting all that extra code...
X
