pic telemetry system
Results 1 to 24 of 24
    ok, i see what your saying for interupt handling and i'll read more when i get fedup trying to sort the comms out...
    here is a little test program i've done to try and debug the problem with the serial comms...
    include "modedefs.bas"
    include "bs1defs.bas"
    Define CONF_WORD = 	0x3d71
    Define  OSC				4				' Set clock speed
    Define  ADC_BITS        10     			' Set number of bits in result
    Define  ADC_CLOCK       3     			' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    50    			' Set sampling time in uS
    SPBRG = 25              ' Set baud rate to 2400
    RCSTA = %10010000       ' Enable serial port and continuous receive
    TXSTA = %00100000       ' Enable transmit and asynchronous mode
    ADT1 var word							' Create ADT1 to store curent ad conversion for AD channel 0
    ADT2 var word                   		' Create ADT2 to store curent ad conversion for AD channel 1
    ADT1MAX var word						' Create ADT1MAX to store curent ADC0 max val
    ADT1MAX = 0
    ADT2MAX var word						' Create ADT2MAX to store curent ADC1 max val
    ADT2MAX = 0
    ADT1VAL var word
    ADT1VAL = 0
    ADT2VAL var word
    ADT2VAL = 0
    ADV1 var word
    TRISE = 255							' Set PortE to all inputs
    TRISD = 0							' Set PortD to all outputs
    TRISC = 0							' Set PortC to all outputs
    TRISB = 0							' Set PortB to all outputs
    TRISA = 255 						' Set PORTA to all input
    ADCON1 = 0 							' PORTA is analog
    HSEROUT [" initialised",10,13]
    SEROUT PORTB.1,t9600,[" initialised",10,13]
    Loop:
    ADCIN 0, ADT1
    HSEROUT [DEC5 ADT1,10,13]
    SEROUT PORTB.1,t9600,[#ADT1,10]
    goto Loop
    From software UART i get...
    +¥ֻ±Í•´
    0
    0
    software uart output is reporting incorrect stop bits when it sends the "initialising" stream...
    I should re-point out, i'm experimenting in a PIC simulator untill i get the right output...
    i have a pair of 16F877's due to arive tomarow and JDM programmer and max232 converts (serial and USB versions) due to arive at any time...
    I know i've not included the half second pause for ADC...
    so, what have i missed out from my initialisations?
    and now... i'm having Floting Point Math 'issues' too...
    FPM sux...
    ok, i got it to output the voltage... so, the analog input now output as a voltage over serial connection... so i'm posting my code for anyone else that wants to use it...
    Loop:
    ADCIN 0, ADT1
    ADT1 = ADT1 / 64
    VARHIGH = ((48 * ADT1) / 10000)
    VARLOW = ((48 * ADT1) - (((48 * ADT1) / 10000) * 10000)) / 100
    HSEROUT ["DEC: ", DEC5 ADT1," V: ",DEC5 VARHIGH,".",DEC5 VARLOW,10]
    GOTO Loop:
    It's actually reading 2% low in the simulation... but thats good enough for me... may be a completely diferent case when in hardware...
    In your soft com maybe you have to use n9600 instead of t9600.
    i tried all combinations of inverted output with none inverted input (into the software uart screen), vica versa and the combo's between...
    but the weird thing is... after the first line it gets all the numbers correct... so, it's almost like a sync problem... but this is all done in sim software, so why would their be and sync problems...
    next job on my telemetry system is to make a counter... or more precisely, an RPM counter...
    I'm mauling over creating a software uart buffer so that while it's waiting for the next AD conversion it can be sending the data...
    I miss the good days of sending a full byte to a hardware uart in one go and have the program go do something else... I loved having 8/16 byte buffers on uarts...
    I also (kinda) loved frying z80 chips when i got hardware wrong... programming in machine code, tape drives, 3" floppies... ahhh those were the days... although, battery backed ram modules were cool...
    But that's EXACTLY what you do with a PICs USART anyway...
    Actually thinking about it...
    You can do all of the above with PICs too...
    Sorry mell, i meant with the software UART... my bad...
    my JDM programmer arived today... still waiting on my pair of 16F877's
    I can't help but wonder why mplab doesn't have JDM programmer in the list... i'm guessin it's a sales thing...
    I got my test board solderd up... it's only 8 mini LED's direct drive from portb whith a knight rider program done myself... simple enough for a test board...
    i'm aware of what you can do with a pic... thats why i switched from the Z80180's (it's a Z80 with dual hardware uarts and memort manager that can access upto 1meg with speeds upto 40MHz) but it kinda hard to get hold of them these days...
    PIC's seem to be the dogs cahuners...
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
  4. calibration clock 12f508
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 11:33
