pic telemetry system
Results 1 to 24 of 24
    Default pic telemetry system
    hi everyone,
    I'm new to pic's and pic basic... however when i was 13 i was writing large BASIC programs on my spectrum and have since gone on to HTML, CSS, PHP etc...
    I'm using MPLAB IDE + PBP 244 for compiling (if thats correct?)
    I'm not using MPLAB IDE to compile because my BAS files are not in the compiler dir... so i used the approch listed here by creating a batch file to execute...
    I'm using PIC16F877-20I/P 's...
    i'm just asking whats the best way of doing the following items...
    1) ADC initialisation, i can't find much info on setting up the ADC's. What i've got sofar is...
    Define  ADC_BITS        10     		' Set number of bits in result
    Define  ADC_CLOCK       3     		' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    50    		' Set sampling time in uS
    Define  ADCON0			%11000001
    TRISA = %11111111					' Set PORTA to all input
    ADCON1 = %10000010					' Set PORTA analog and right justify result
    First off, i need to correct the clock source to XT not RC so, will do that later once i found the value it should be...
    My code is directly dependant on the ADC values that come in (nothing to run while it's waiting)... so i want the ADC to run as fast as possible... have i got it right? anything missing?
    2) telemetry link to my laptop... laptop has IR port so I want IR link to PIC to recieve ADC valuse and io values etc...
    i have the IR header (surfice mount mind!) the only way i can think of doing it is to direct drive the IR TX with a FET and use another FET on the reciever...
    I'm also assuming i should be using serin/out at 9600 none inv...
    I want it looping as fast as possible and give me as many ADC samples as possible per second...
    3) i can't find much info on ADC calibration... aparently the ADC can only do upto 5V, after that you need to do something externally? but can't seem to find out exactly what? can someone kick me in the right direction?
    Thanks everyone
    Quote Originally Posted by comwarrior View Post
    hi everyone,
    And this tells me you are ??teen . . . no matter, Welcome comwarrior. We always welcome Sharp Kids, when I was 13 only Governments and Giant Corporations had computers, and they used punch cards.
    I'm not using MPLAB IDE to compile because my BAS files are not in the compiler dir... so i used the approach listed here by creating a batch file to execute...
    I'm just asking what's the best way of doing the following items...
    1) ADC initialization, I can't find much info on setting up the ADC's. What i've got so far is...
    Thanks everyone
    OK, go into the FAQ section of the forum,
    http://www.picbasic.co.uk/forum/forumdisplay.php?f=16 ,here you will find good things, like : http://www.picbasic.co.uk/forum/showthread.php?t=543 , and make use of this to search the forum: http://www.google.com/custom?hl=en&c...ch&sitesearch=
    ADC does not need Calibration... well... how pedantic do you want to be...
    It will always give you steps of 1/255 or 1/1023 (depending if you are in 8 or 10 bit mode) of VREF. So if VREF is 5v, you get steps of 5*(1/255) or 5*(1/1024) accordingly.
    If VREF=VDD for example, then you rarely get 5.0000v, you'll usually have some arbitrary figure between 4.9 and 5.1v. That can throw your math, if you're making a thousand units and each one has to be precisely identical to the next. It's something that either usually you can live with, or design out with more precise Voltage References or circuitry.
    For high speed, I probably wouldn't chose to use ADCIN. It only takes a tiny number of instructions to grab Data from the ADC anyway, and it's just as easy to do it manually...
    @ joe - Knowledge, but no wisdom = unhelpful
    Practice what you preach and look at my profile it will tell you how old i am...
    @mel - completely avoided the question you tried (and failed) to answer = unhelpful
    I allready know it's set to 5 volts... the question was what do you use to measure more than 5 volts?
    Do you two really think I’d post here without spending days trying to find the info myself? that single one liner "...when i was 13 i was writing large BASIC programs on my spectrum and have since gone on to HTML, CSS, PHP..." should tell you I’m an experienced programmer capable of learning on my own and know to check with people that are 'supposedly' in the know to make sure I’m on the right tracks...
    So far, I’m not impressed...
    Correct. I did not look at your profile, I do not care about your profile, I was willing to help you even if you were 13. It is a little unusual for a 27 year old MAN to profile himself from his thirteenth year, nevertheless in my rush before going to work, I tried to help. Do not worry, I will not make that mistake again. I believe you just hacked off 2 people, 1. Mel, most able to help, 2 Me, most willing to help. So here is My offer . . . Forget everything I said in My first post and have a nice life Dude.
    TFB
    joe, i don't mind 'hacking people off' when 'experts' post that level of rubbish...
    Besides, i doubt it's only two people...
    Perhaps you should do a search for me on utube...
    Don't worrie about the IR link... I've finally (after over yet another day totally searching) found the datasheet for the IR trancever i'm using... and it has the hardware i asked about allready built in AND it is on the same wavelengh as PC IR comms...
    So, we can cross that one off... I found some pic simulation software and it would apear my ADC's are ok... will be playing more with the program, i like it...
    Just one left... hmmm, how to measure more than 5 volts...
    Your second post and you are already offending the people trying to help you. Hmm ... Comwarrior, interesting choice for a name given these three postings. Perhaps you should stick with the advice given in the first reply, and use the search tools you were offered instead.
    I'm with Joe, I would have guessed 16. 27? Really?
    http://www.scalerobotics.com
    I cant' resist!
    If 13th on a Spectrum (around 1983) now maybe 40 something. But this does not have to do with the attitude. Either you have it or not.
    Being polite is a way of life.
    Anyway, I do respect every member of this forum, but some deserve a little extra like Melanie.
    Did not got exactly all the answers? Why not re-ask? No hurt. Blaiming for un-helpful and no-one is going to help in the future. Why bother? Our time is precious besides...
    1. Set up is fine.
    2. You got it. But consider to use (if you don't) the Usart for most efficient way to send receive data and also interrupts (look for DT-INTS on the forum).
    3. As stated a resistive voltage divider is all that is needed. Simple ohms law to find the values according to your Vin/Vout needs.
    I dunno, maybe he thought the Google link was the standard Google and not a PICBASIC custom link, I was guessing 17, really what adult talks about their code exploits at 13 anyway? Usually I test the code and pour over the data sheets, didn't have time, but I know everything HE is looking for is here already. Keep handin' out those fish Ioannis, I am sure the recipients appreciate them. Maybe YOU CAN impress him. , funny, I never even thought of trying to impress anybody,incidentally, to everyone who has EVER Tried to help me, Thank You.
    JS
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 08:25
  4. calibration clock 12f508
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 10:33
