How to receive stream of bytes using PIC USART
Results 1 to 35 of 35
    Jun 2009
    The SpO2 module I use is of none parity.
    I wonder the PIC have the problem to read the bytes if the bytes are sent into PIC in endless stream. I tried to send only 5 bytes, 10 bytes and 15 bytes data in SpO2 module's data format and the PIC can process well using the code I wrote.
    Then I tried to let PIC sent out each byte it read in from a endless bytes stream. The output of the PIC is different from the data it read in.
    Dec 2005
    Quote Originally Posted by unifoxz View Post
    That's not the issue. How many STOP bits is the issue. If, as the only reference I could find for the BCI protocol says, it uses 8N2, you cannot handle it - all of the PBP methods require 1 stop bit. Two stop bits could explain the erratic results. You need to provide a link to the datasheet for the specific SP02 device you are using.
    I double that, although have asked for it earlier.
    It seems you loose synchronization. But we are only guessing here as we have no informations about you device.
    Jun 2009
    I try my best to translate the manual as the manual is originally written in Chinese language. The manual is too simple and not really provides the details.
    serial port setting:
    • 1 start bit + 8 data bit + 1 stop bit, no parity
    • baud rate: 4800 baud
    • 5 bytes format, 60 packages per second, bit 7 is the synchronous bit
    byte 1:
    • bit 7: synchronous bit, as 1
    • bit 6: 1=instruction for pulse sound
    • bit 5: 1=SpO2 decrease, 0=OK
    • bit 4: 1=searching time too long, 0=OK
    • bit 3-0: signal strength (0-8), represent signal strength of pulse
    byte 2:
    • bit 7: synchronous bit, as 0
    • bit 6-0: pulse wave diagram
    byte 3:
    • bit 6: pulse rate bit 7
    • bit 5: 1=search pulse, 0=OK
    • bit 4: 1=sensor error, 0=OK
    • bit 3-0: pulse bar diagram
    byte 4:
    • bit 6-0: pulse rate, (bit 6 to bit 0)
    byte 5:
    • bit 6-0: SpO2
    Dec 2005
    OK - it has only one stop bit. It appears that various manufacturers use their own protocol.
    60 packets per second x 5 bytes per packet x 10 bits per byte = 3000 bits per second which, at 4800bps, means 30 (or fewer - depends on pace) idle bit-times between packets.
    I would capture 10 bytes, scan them for the first initial byte (>127) and then look at the following 4 bytes for your data.
    EDIT: 9 bytes would guarantee one complete packet.
    Hmm, seems that is like the pdf I posted. Is it the same module?
    Based on the infos and the idea of Dave's:
    array    var   byte[9]
    temp    var   byte
    i          var   byte
    j          var   byte
    get_new_data:
    SerIn2 PORTB.7,16572,[str array\9]
    for i=0 to 8
        temp=array[i]
        if temp.7=1 then goto send_at_9600
    next i
    hserout ["Not found!",13,10]
    goto get_new_data
    for j=i to i+4
    hserout [array[j]]
    next j
    goto get_new_data
    Hope this will get you started. Don't forget the defines for the Hserout command to set it at 9600.
    Dec 2005
    You need only scan the first five bytes to find the start of a packet. And you can save one step on each loop.
    for i=7 to 39 STEP 8
        if array[0].i=1 then goto send_at_9600
    next i
  1. Replies: 6
    Last Post: - 31st August 2007, 09:31
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 15:43
  4. Replies: 1
    Last Post: - 6th September 2005, 16:32
