How to receive stream of bytes using PIC USART
Results 1 to 35 of 35
    I did a little search in the web and found that the modules for medical applications use the so called BCI protocol with 4800 8-ODD-1 serial setup.
    Data frames are 5 bytes long and on the first byte the 7th bit is 1 while on the restbit 7 is set to 0.
    So, may be you get one byte at a time and check the bit 7 only for it to be 1. Then get the rest and store in a byte array of 5 elements.
    If there is not a sync byte or a significant pause between frame transmissions, PIC cannot discriminate the start byte. That is why you get confussing results.
    One untested example might be:
    array    var   byte[5]
    index    var   byte
    index=0
    get_new_data:
    SerIn2 PORTB.7,16572,[B0]
    if B0.7=1 then
        array[index]=B0
        index=index+1
    if index=5 then process_data
    goto get_new_data
    Dec 2005
    Where did you find the protocol description? The only reference I found indicated it uses two stop bits.
    Hi Dave. I found the attached pdf that is implying the protocol.
    Jun 2009
    The SpO2 module I use is of none parity.
    I wonder the PIC have the problem to read the bytes if the bytes are sent into PIC in endless stream. I tried to send only 5 bytes, 10 bytes and 15 bytes data in SpO2 module's data format and the PIC can process well using the code I wrote.
    Then I tried to let PIC sent out each byte it read in from a endless bytes stream. The output of the PIC is different from the data it read in.
    Dec 2005
    Quote Originally Posted by unifoxz View Post
    That's not the issue. How many STOP bits is the issue. If, as the only reference I could find for the BCI protocol says, it uses 8N2, you cannot handle it - all of the PBP methods require 1 stop bit. Two stop bits could explain the erratic results. You need to provide a link to the datasheet for the specific SP02 device you are using.
    I double that, although have asked for it earlier.
    It seems you loose synchronization. But we are only guessing here as we have no informations about you device.
    Jun 2009
    I try my best to translate the manual as the manual is originally written in Chinese language. The manual is too simple and not really provides the details.
    serial port setting:
    • 1 start bit + 8 data bit + 1 stop bit, no parity
    • baud rate: 4800 baud
    • 5 bytes format, 60 packages per second, bit 7 is the synchronous bit
    byte 1:
    • bit 7: synchronous bit, as 1
    • bit 6: 1=instruction for pulse sound
    • bit 5: 1=SpO2 decrease, 0=OK
    • bit 4: 1=searching time too long, 0=OK
    • bit 3-0: signal strength (0-8), represent signal strength of pulse
    byte 2:
    • bit 7: synchronous bit, as 0
    • bit 6-0: pulse wave diagram
    byte 3:
    • bit 6: pulse rate bit 7
    • bit 5: 1=search pulse, 0=OK
    • bit 4: 1=sensor error, 0=OK
    • bit 3-0: pulse bar diagram
    byte 4:
    • bit 6-0: pulse rate, (bit 6 to bit 0)
    byte 5:
    • bit 6-0: SpO2
  1. Replies: 6
    Last Post: - 31st August 2007, 09:31
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 15:43
  4. Replies: 1
    Last Post: - 6th September 2005, 16:32
