How to receive stream of bytes using PIC USART
Results 1 to 35 of 35
    Hmm, seems that is like the pdf I posted. Is it the same module?
    Based on the infos and the idea of Dave's:
    array    var   byte[9]
    temp    var   byte
    i          var   byte
    j          var   byte
    get_new_data:
    SerIn2 PORTB.7,16572,[str array\9]
    for i=0 to 8
        temp=array[i]
        if temp.7=1 then goto send_at_9600
    next i
    hserout ["Not found!",13,10]
    goto get_new_data
    for j=i to i+4
    hserout [array[j]]
    next j
    goto get_new_data
    Hope this will get you started. Don't forget the defines for the Hserout command to set it at 9600.
    Dec 2005
    You need only scan the first five bytes to find the start of a packet. And you can save one step on each loop.
    for i=7 to 39 STEP 8
        if array[0].i=1 then goto send_at_9600
    next i
    Jun 2009
    Thanks for the suggestions, but the result I get is still not correct.
    Have anyone tried to send an endless stream of bytes to PIC and then resend the stream back to PC? Will the input bytes same as the output bytes?
    Please post you complete code as is now.
    Of course the PIC will send the correct bytes as received, why shouldn't??
  1. Replies: 6
    Last Post: - 31st August 2007, 10:31
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 16:43
  4. Replies: 1
    Last Post: - 6th September 2005, 17:32
