I have tried with sending out data bytes that received from the modules to PC immediately but the data displayed on the PC is different from the data that I connected the module directly to PC. It seems like the data of the bytes stream corrupts when it passes through the PIC.
This is the testing code:
What should I do to avoid the data from crashing in Rx buffer of PIC UART, provided I cannot control over the stream of bytes received?Code:INCLUDE "modedefs.bas" DEFINE LOADER_USED 1 DEFINE OSC 20 B0 VAR BYTE 'PB.7 = Rx, PB.6 = Tx TRISB = %10000000 loop: '4800 baud rate 'read byte from SpO2 module SerIn2 PORTB.7,16572,[B0] 'send byte to PC SerOut2 PORTB.6,16572,[B0] GoTo loop End
