Thanks Alain!
Thanks Alain!
Thanks guys,
I knew someone would have it !
Now to work out how to to 10mS int's on a 18f2550 running at 48MHz !!
Bill
PICMultiCalc gets runtime errors in windows 7.
Is their a newer version than 1.3.1?
This is a much used utility and an update would be appreciated.
Norm
Hi Norm,
I run it on Win7-64bit and don't get any runtime (or other) errors. I don't know what version I'm running but I can check tonight. If you haven't already tried it, try running it as administrator and see if that help. I've had several apps where doing that is neccessary for it to work.
Running as administrator didn't help in 32 bit windows 7 professional.
I have the following NET's installed by default in case this is a Microsoft VB supportive files issue:
Microsoft® .NET Framework Version 2.0.50727.4927
Microsoft® .NET Framework Version 3.0.6920.4902
Norm
Hi Norm,
I had problems installing on win98 required a file not in win98, got it off the net.
Have you tried to run in compatibility mode ?
Tried compatibility mode, no luck.
Tried installing missing files found in XP but no luck.
Norm
I had to download & install Microsoft ActiveX control Pad to get LCD tool working.
I had to download & register MSSTDFMT.DLL to get Timer tool working.
All tools worked after that.
Nice utility, I had the old SPBRG version.
If you get this in Win 7 64bit:
ActiveX Control Pad Setup:
the app was unable to start correctly (0xc0000142)
Run in XP compatibility mode.
To register MSSTDFMT.DLL in Win 7 64bit:
- download the file from microsoft.
- copy to C:\Windows\SysWOW64 folder
- RUN REGSVR32 C:\Windows\SysWOW64\MSSTDFMT.DLL
It is surprising, but on my new and fresh Win7-64Bit system, with no VB studio installation if that matters, I did nothing special. Just executed the Steves nice job. It runs with no error messages!
Lucky me
I don't have VB6, MCSP, PBP or anything else programming-oriented on the Win 7 64-bit system yet either; just FS-X, PSP-XI, Open Office and Turbocad 11.
I bet you have software that already have those DLL included.
