35mA led with 25mA pic output?
Results 1 to 34 of 34
    xnihilo's Avatar
    xnihilo Guest
    There are LEDs and then there are LEDs. They can vary widely in their brightness output. For example, these are 2 green LEDs in a 5mm, T-1 3/4, thru hole package. Both are rated at a test current of 20mA.
    http://search.digikey.com/scripts/Dk...me=511-1191-ND
    This one has a rated output of 100mcd. This is typical of commonly available LEDs, 50 -300mcd.
    http://search.digikey.com/scripts/Dk...FPG1-15Q-A3-ND
    And this one has a rated output of 34,000mcd.
    The output of the 2nd. one is 340 times that of the 1st. And it is not even a matter of price - both of them are about the same. So if the LED is bright enough for you at 20-25mA, just go for it. If not, get a brighter one. No need to mess with paralleling outputs, using BJT's or MOSFETS etc.
    34000mcd... awesome! I didn't even think such exist
    What if I put one on my car ...
    Quote Originally Posted by xnihilo View Post
    34000mcd (http://en.wikipedia.org/wiki/Candela) sounds really bright and really impressive, and they are fairly bright when viewed straight on...but it's not all that.
    These are what I used in my toobz...
    http://www.philipslumileds.com/pdfs/DS05.pdf
    70mA drive current with a 1/2 power viewing angle of 90 degrees.
    They aren't the Luxeon super bright, multi-watt, power LEDs, but they do well.
  1. comp music with pic Sounds - Aka BeepMaster
    By flipper_md in forum Code Examples
    Last Post: - 20th September 2010, 07:04
  2. Calulating BJT base resistance for PIC led switching?
    Last Post: - 20th November 2008, 09:41
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. Capacitor on PIC output
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 21st March 2008, 20:10
  5. PIC16F877A PAUSE command
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 12th December 2006, 02:40
