Hi Xnihilo,
If you want to keep the full LED brightness you must use some sort of buffer (a small NPN or PNP transistor or a low power N or P channel FET or MOSFET will be your best choices) combined with a 82 Ohm resistor for your 2V 35 mA LED.
If you don’t mind loosing some brightness a limiting resistor (in your case 120 Ohm will give you 25 mA or 150 Ohm will give you 20 mA).
All you have to do is trying and decide.
Nick
