35mA led with 25mA pic output?
Results 1 to 34 of 34
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by RussMartin View Post
    You are misreading the table.
    The third line is saying that the maximum DC forward current is typically 35 mA. It means that for some of the LEDs, it may be a little more and for others a little less, but what it is telling you for sure is, "Don't exceed 35 mA."
    The first line of the table is probably more indicative, where it shows a typical forward voltage (Vf) of 2 VDC when run at 12 mA. This sounds like a typical operating condition and is probably as bright as it needs to be.
    So you need a series resistor of 220 ohms (13.6 mA), but you can probably use down to 150 ohms (20 mA).
    ... Right. Thank you.
    Stuff like "Vcc=Min,Iol=MAX,Vih=MAX" is not yet so obvious for me.
    .....Information removed at the risk of annoying RussMartin......
    See post below....
    Omaha, Nebraska USA
    Most of those abbreviations are listed at the bottom of the pages of the datasheets.
    If not there, usually a Google-search and/or Wiki will get you the answer on whatever the abbreviation means. In this case:
    Vcc = voltage common-collector, generally positive voltage input
    Iol = current, output, low (sinking current)
    Vih = voltage, input, high
    . . . and which have nothing to do with either his question or his LED. I believe he was conveying his thanks to me, not asking another question.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Well excuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuse me
  1. comp music with pic Sounds - Aka BeepMaster
    By flipper_md in forum Code Examples
    Last Post: - 20th September 2010, 07:04
  2. Calulating BJT base resistance for PIC led switching?
    Last Post: - 20th November 2008, 09:41
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. Capacitor on PIC output
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 21st March 2008, 20:10
  5. PIC16F877A PAUSE command
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 12th December 2006, 02:40
