easyHID question
Results 1 to 40 of 49
Threaded View
  1. #10
    As long as you've done everything exactly right, then yes, An EasyHID program will connect to the computer without any hassles.
    Quote Originally Posted by keymuu View Post
    I tried how it worked with it on, however without success, that seems not change anything, so the fault is somewhere else...
    When you have MORE THAN 1 problem at the same time. It's often hard to find them, because simple trial and error no longer works. No matter what you change, it still won't work.
    In the case of the VREGEN. IT MUST BE ENABLED!!!
    Please try the attached .HEX file. It's for an 18F4550 @12mhz.
    I've set all the configs in the program, so allow meProg to use those settings.
    Remove the .TXT extension.
    All it does is connect the USB.
    All other pins are set to input.
    MCLR is disabled.
    After programming, be sure to cycle the power ON/OFF once.
    This should tell us if it's hardware, or software.
  1. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 19:19
  2. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  3. HIDMakerFS versus EasyHID
    By Demon in forum USB
    Last Post: - 15th August 2006, 09:01
  4. EasyHID VB help with multiple HID's
    By pfinfrock in forum USB
    Last Post: - 6th October 2005, 20:16
  5. Replies: 0
    Last Post: - 5th September 2005, 10:09
