Thank you indeed...
It gives just what you said, on PORTA.2 one can see a 50% cycle about 0.5Hz. When I plug the cable there is a very short pause in that cycle and then it continues again. So at this point I was quit surprised when I saw that D+ and D- worked as they should, one was down and the other up. I heard also the plug and unplug signals (ding-dong and dong-ding) and the port did not die, at least when plug and unplugged three four times.It blinks PORTA.2 at a 0.5hz rate. 1 sec on, 1 sec off.
I've re-enabled the Oscillator switchover, in case the main isn't working. If it's switching over, the blinks will get REALLY long. (~20 sec)
WDT is on, in case it locks up somewhere.
So how was this possible?
My mistake...![]()
If this (with toggling RA2) was working, why was not the previous one working earlier? At this point I'm sure that I did not use the real file because I renamed it to the one that was last compiled and could so (so I taught) straight away (Ctrl-P) compile it with meProg. Now I know that, that file (last compiled) is not necessary the one you think of if you do not come via/from MicroCode Studio. Now I now (can see) that the name of the used file is also in the caption.
Today I used for the first time File/Open in meProg when I realized that this is also possible, I have not had need to that earlier when one could start the programmer from MicroCode Studio. When I now programmed it (straight from meProg) I can see D+ and D- to be opposites and also Vusb to be 3,20V.
I don't see how this could solve the original problem when it suddenly was not hw matter after all. This misleading thing (suspected hardware failure) was solely and alone my fault, my carelessness...![]()
It seems to me that the meProg overwrites all configurations. I have verified that with the MCLR, it is not disabled when it is "burned" into PIC. There might be some conflict with original configuration and implemented ones.And MCLR is still disabled.
Used configurations are as an attachment.
