Matrix Keypad routine
Results 1 to 40 of 135
Threaded View
  1. #14
    Oct 2008
    Exclamation Need help desperately!!!
    I'm doing a temperature control system. Pretty new to PIC programming. I have managed to display temperature on the LCD using an LM35 sensor and a 16 x 2 lcd with a 16F873. I want to add on a 4 x4 matrix keypad so that i can set setpoints to switch a relay and a low warning buzzer I have no idea how to program for the above mentioned add-ons. Please could someone help me. below is my code which will obviously need additions and a scematic of my circuit is attached . Please could somebody help me with this!!
    Define LCD_DREG PORTB
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 5
    Define LCD_EREG PORTB
    Define LCD_EBIT 4
    dEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    adval var word ' Create adval to store result
    temp var word ' Create temp to store result
    temp1 var word ' Create temp1 to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %11000001 ' Configure and turn on A/D Module
    Pause 100 ' Wait 0.1 second
    loop: ADCON0.2 = 1 ' Start Conversion
    AGAIN: Pause 1
    If ADCON0.2 = 1 Then AGAIN ' Wait for low on bit-2 of ADCON0, conversion finished
    adval.highbyte = ADRESH ' Move HIGH byte of result to adval
    adval.lowbyte = ADRESL ' Move LOW byte of result to adval
    Lcdout $fe, 1 ' Clear screen
    temp=50*adval ' Conversion to Degrees
    temp=temp/100
    Lcdout "TEMP = ",DEC temp,$DF,"C" ' Display the value of temp
    temp1 = temp*18 ' Conversion to Fahrenheit
    temp1 = temp1+320
    temp1 = temp1/10
    lcdout $FE,$C0, "TEMP = ",dec temp1,$DF,"F" ' Display the value of temp
    Pause 1000 ' Wait 1 second
    Goto loop ' Do it forever
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  3. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 22:25
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 22:33
