RS232 7-E-2?? Driving a BetaBrite
Results 1 to 17 of 17
    Quote Originally Posted by Eeyore View Post
    Mackrackit,
    Unsure why you could not follow my original post, but it seems clear that am I writing code for a PIC (in the PBP forum). Are you not able to follow the reasoning behind my inclusion of the Dios example?
    I guess you are just to smart for me. First time poster post code for another compiler and states they do not want to learn anything else. I do not know what I was thinking
    All you had to do was ask. How do I do 7E2 at 9600?
    First set the define for SEROUT2
    DEFINE SER2_BITS 9
    That should give a false bit.
    Then to get the 7E, use the mode number 24660.
    You may want to check the manual on this. And if you are using the hardware port you will have to check the data sheet for your PIC.
    BTW... Welcome to the forum.
    Same thoughts going on here...
    This situation is atypical... Surely not the norm for a first time post.
    Sep 2008
    Sorry if I got off on the wrong foot, but I thought your initial reply was being sarcastic (thought I was being told where to go, literally). Now that I see your reasoning, I understand that I misinterpreted your comment.
    Thank you for the suggestion, I will try it over the weekend
    Talking
    Oh...don't worry...it was sarcastic!
    Like I said, most 1st posts go something like this:
    I can't blah-blah-blah...
    Well, have you tried blah-blah-blah
    Can you teach me how to blah-blah-blah
    Have you got the manual for blah-blah-blah
    There's a manual for blah-blah-blah?
    Der-der-der-der...
    We are good at sarcasm too
    Like I said check the manual about the 2 stop bits. I have not needed to do that but in theory...
    Let us know how it goes.
    " THE BOOK " Says, for an instance . . . "It should only be used if parity is selected (bit 13 = 1) . . . . and several other instances of defineing individual bits . . . is there a register that can be addressed directly like the Tris or INTCON registers ? I mean indirectly there is for the lower 12 bits by using the appropriate " MODE" settings, but is there a register you can set manualy ?
    Joe,
    I read somewhere from one of the gurus about having 2 stop bits. They were setting a register using the hardware port, I can not remember whitch one though, to 9 bits and the 9th acting as a false bit. So I figure it might work using software serial too?
    Hi Dave, Well that gives me something to do, I will write a short program using serout2 and take the ASM, MAC and list files apart looking for the answer. I figure at the least If I can figure out what those commands do, it might be easier to put asm snippets in than writing endless Defines and hoping it works.
    <b>
    DEFINE</b> SEROUT2_NON_INTUITIVE = 1
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  2. Replies: 4
    Last Post: - 15th April 2009, 02:54
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
