" THE BOOK " Says, for an instance . . . "It should only be used if parity is selected (bit 13 = 1) . . . . and several other instances of defineing individual bits . . . is there a register that can be addressed directly like the Tris or INTCON registers ? I mean indirectly there is for the lower 12 bits by using the appropriate " MODE" settings, but is there a register you can set manualy ?
