16F88 ADC problem
Results 1 to 20 of 20
    Quote Originally Posted by greensasquatch View Post
    Sinoteq,
    thanks for the links. I'm thinking I should stop being so cheap and just get a programmer from microchip now. This JDM just doesn't seem to do everything I want it to do.
    Skimask,
    I have erased the chip using WinPic (or at least winpic thinks it's erasing the chip, I get no errors) but when i try to reprogram I get verify errors.
    I'm going to go back to tinkering with my 16F627A's and RF for a while until I get another 16F88. I'll stay away from using INTRC_OSC and MCLR_OFF together for now.
    At least I know what happened to my 12F675's now, too bad I bent the pins and tossed them.
    You guys are great, thanks again.
    I have 2 JDM programmers, they are different from one another, on each of them, printed on the circuit board is the orientation of the pic chips and location, As I said, they are WAY different in respect to each other. as far as issues of MCLR on/off, INTRC vs HS, xt . . . NONE. The issue I seem to have is one of them the ZIF socket is beginning to wear (the Plating) and I got tired of having to wiggle the chips before programming, that's why I have 2. #2 came in the mail today, works fine so far using ICProg.
    Why not swap out the ZIF socket?
    Doable, 18 bucks delivered from CA now I have a backup. I have not yet figured out how to program 18f4550 with these, I think my PC serial port is too weak, the new programmer has a 12v input which can be jumpered in, I will try that next, and I think there is a PICKIT2 in my future, depends if my sometimes employer has caught sight of the payroll fairy, till then wallet goes under the pillow
    EDIT: 12v did not do it either.
    When I use my PicStart+ with 18s, I have to add a 22uf cap between the VDD and VSS, most time just on one side will do. Bit of a pain in the ziff. But the adapter for ICSP has them built in.
  1. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  2. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  3. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  4. Problem with 16F88 controlling h-bridges
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 05:16
  5. 16F88 using comparators AND the adc
    By jpeakall in forum mel PIC BASIC Pro
    Last Post: - 13th May 2005, 02:08
