Quote Originally Posted by greensasquatch View Post
I've been going over my code line by line. Finally found something odd. And I've come to the conclusion that this is the last time I copy lines from somebody else's code.
I'm sure the line <b>PROTECT_ON</b> is the reason i can no longer use this chip.
If PROTECT_ON is used, that means you can't READ the chip, doesn't mean you can't write to it.
ERASE the chip completely...then reprogram it...
