I have an MELabs programmer, and I've been very happy with it. The tech support is great, too. I had a chip with the same issue as you, so I called and asked about it. They said that the programmer relies on MCLR to program it--and since you turned it off, there is an issue. If you need to make that pin an output, you need a 1-2 second delay before setting the Tris. This might not be your exact issue since some of your settings were pasted from elsewhere, but it is something to keep in mind.
BTW, it's nice when the tech support for your hardware and software come with the same phone call.
