copy-string 'function'
Results 1 to 28 of 28
    Default Eurh?
    what about the crank bolts? connecting rod end caps? hmm guess it's in the manuel. lol
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by nomad View Post
    I haven't gone that deep into an engine yet. Done things like; head gaskets, water pumps, alternators, starter motors, radiators, heater cores (what a nightmare), brakes, exhausts. You're probably right in saying that there is a few other bolts that should be desirably torqued to (n) ft lbf -- foot pound force.
    Trent Jackson
    May 2008
    Florida
    All bolts have dataheets, all bolts have torque specs. Based on PICBaisc Forum replys all bolts must be torqued.
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by manwolf View Post
    This is true. Robots need to know this information, therefore engineers will calculate a torque spec. But when a mechanic installs your new starter motor, those bolts will be tightened to approx 1/2 a turn, which is probably about 20 ft lbf at a very wild guess.
    Trent Jackson
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 12:53
  2. Replies: 11
    Last Post: - 12th July 2008, 02:36
  3. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:50
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 10th July 2005, 23:17
