You didn't get it from mister-e
While we're on the subject of optimization...
http://www.picbasic.co.uk/forum/showthread.php?p=30533
But really, this things got some serious shortcomings.
What if the person doesn't want a 255 byte string? Maybe they only need 32. Your routine will wipe out other variables well beyond the array.
What if they have more than 1 array? It only copies to an array called string.
What if they're using a 16F?
Why do they have to manually change MOVE?CW to MOVE?CN. Why not detect when PBPL is used, or have a separate macro for 32-bit addresses. Or better yet, do the tblrd's or EECON rd's manually, instead of relying on ReadCode. Then it's easy to handle over 64k or 16F's. Even without 2.50
Make it a true "PBP Extension".
