copy-string 'function'
Results 1 to 28 of 28
    T.Jackson's Avatar
    T.Jackson Guest
    I think you've got some form of obsessive compulsive disorder Jeremy. There's some really good medication available to treat that sort of thing. Nothing to be ashamed of mate -- we all get sick throughout some stage of our lives. I personally had a mild case of depression a few years back.
    Trent Jackson
    Trent Jackson
    Yep, that's me...that's me...that's me...that's me...
    I see that [Submit Reply] block and I can't pass it up....
    I have to click on it.
    Doesn't matter what the subject is...I have to click on [Submit Reply]
    I aches to have me, just me, and only me click on [Submit Reply] I must [Submit Reply]
    Let me know how it all works out for you when you get over it....or don't....preferably option #2...nah, never mind, take option #3...repeatedly...then again, I have been applying poly to my latest couple of projects...maybe I should ventilate a bit more...wait a minute! I'm outside. Well, not really outside, more of a screened-in greenhouse. How much more ventilation do I need? This laptop is hard to see in the sunlight. Do they make a pill for that too?
    T.Jackson's Avatar
    T.Jackson Guest
    I think it's a mild case because you're not really that particular with your work, as in being eccentric enough to the point where every non-critical bolt on an engine must be tightened exactly the same to a specific amount of torque when there's absolutely no need to.
    Trent Jackson
    What is this 'torque' you speak of?
    And how tight should it be?
    T.Jackson's Avatar
    T.Jackson Guest
    Well, in my humble opinion the only bolts on an engine that need to be tightened to a specific, exact amount of tension are the head bolts. In all other cases 1/4 to 1/2 a turn adequately suffices. Perhaps I'm wrong? I'm not a mechanic, but I am in the process of practically rebuilding a 2001 model, Ford Falcon AU2, XLS UTE.
    Trent Jackson
    Default Eurh?
    what about the crank bolts? connecting rod end caps? hmm guess it's in the manuel. lol
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by nomad View Post
    I haven't gone that deep into an engine yet. Done things like; head gaskets, water pumps, alternators, starter motors, radiators, heater cores (what a nightmare), brakes, exhausts. You're probably right in saying that there is a few other bolts that should be desirably torqued to (n) ft lbf -- foot pound force.
    Trent Jackson
    May 2008
    Florida
    All bolts have dataheets, all bolts have torque specs. Based on PICBaisc Forum replys all bolts must be torqued.
    Trent Jackson
    You could make that assumption, and you would be wrong.
    I usually just crank 'em down so they wont come off.
    T.Jackson's Avatar
    T.Jackson Guest
    With regards to 1/4 to 1/2 of a turn I reference to Motorcraft components with what I'm saying. Namely the installation instructions for spark plugs and water pumps.
    Trent Jackson
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 08:50
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
