3 Digit LCD and Driver IC
Results 1 to 11 of 11
    Jun 2008
    Washington
    Thanks skimask. the 1x8 uses a KS0066U controller, and the 2x8 uses a SPLC780D. The supplier said both were "equivalent to the 44780". I picked them to get some experince with the two different controllers. I figured it was a good way to learn.
    I picked the 120x32 (I checked, and they publish this as the size, maybe it is a type) because it had a data sheet that at least looked like something I might be able to grasp (at least enough to get started! ha).
    thanks for the tip on the thread, I will be checking it out.
    FYI, here is the link to the 120x32
    http://www.newhavendisplay.com/index...rod/prd266.htm
    Thanks for the help
    Jun 2008
    Washington
    skimask,
    Thanks for the great thread on the 122x32. it is a huge help.
    Quote Originally Posted by ClayE View Post
    Sure, 2 different controllers that are both 'equiv to the 44780'. In other words, they'll mount the same, most likely initialize the same, and except for the different in the number of lines, operate the same.
    I just had a look at that datasheet. The company may have screwed up the datasheet all the way thru, or it really is a 120x32 LCD. If it is actually a 122x32, you'll notice 2 blank vertical lines in the middle of the LCD once you get it up and running, then you'll know it's a 122x32.
    But it does use the SED1520 controller, the same thing as 'my' 122x32 GLCD, so the code should transplant right over.
    Jun 2008
    Washington
    Default My 2x8
    well I got my LCD modules in and after lots of studying, figured out how to hook it up. couldn't get anything on the display, then ended up getting junk. after couple of code changes, and finally changing the LCD_DATAUS to 50 from 20, I'm getting what I expect on the display. I'm still getting the first line all "black squares" (or what ever you call it when all the dots are on) on power up. They clear with the clear command, but seems like it shouldn't be doing the "light up the first line" thing when powered up. I'll keep grinding to figure it out. (the second line of the display does not do this).
    I've got more than a few styles of parallel LCDs in the shop.
    The bulk of them power up to a cleared screen. A couple of them power up the way you describe, one of them powers up with random garbage all over the screen every time. It's probably got to do with how messy the power supply is or it's rise rate or...well, I don't care. As long as they 'clear' after they 'boot', I'm happy.
    Are you able to display what you want to or does it come out garbage?
    Hello ClayE, could we peek at the code up through the first lcdout routines? You might try . . .LCDOUT 254,1, "MyString"
    That should clear the LCD and print MyString on line 1
  1. graphics lcd with lcdout style serial??
    By reaper0995 in forum Serial
    Last Post: - 27th March 2008, 19:57
  2. LCD will not start
  3. LCD driver compatability
    By jmgelba in forum General
    Last Post: - 5th November 2005, 02:58
  4. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 13:18
