U2 ICSP connection
Results 1 to 4 of 4
    Question U2 ICSP connection
    Hello,
    I have the LAB-X1 with U2 USB programmer. I know the LAB-X1 uses 12v to program a PIC via U2. Does anyone have a schematic of connections to an external board for in-circuit program via U2 hookup with 12v power supply? The LAB-X1 schematic doesn't seem to have that info.
    Thanks!
    Nick
    Quote Originally Posted by Macgman2000 View Post
    What? Not very clear here...
    Do you want the U2 -> X1 connection diagram or the 12v power supply diagram or the X1 schematic?
    Doesn't the manual have one? Isn't there one at www.melabs.com? Yes?
    May 2008
    Florida
    Hello,
    Thanks!
    Nick
    Nick you sure about that 12volts?
    The MCLR pin on the PIC will be driven to approximately 13V during programming. This raises two concerns. The first is that your circuit must allow 13V on the pin. Don't connect the pin directly to the Vdd rail. The second concern is that the rest of your circuit may need to be protected from this voltage. If 13V on the MCLR pin might put at risk other components on your board, use a diode in series with the RESET pullup to keep the 13V off of the Vdd line.
    Pin out and suggestions
    http://picbasic.com/support/icsp.htm
    Smile U2 ICSP connection
    Thanks all for the info. Yes power supply says 12v, it was packed out with my lab-x1. open circuit voltage says 12.5v. It works just fine in programming.
    Nick
  1. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 21:13
  2. 10f200 Icsp
    By dhouston in forum General
    Last Post: - 18th September 2008, 15:23
  3. CO2 MG811 sensor connection
    By elektoro2009 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 01:49
  4. Replies: 1
    Last Post: - 11th December 2007, 00:57
  5. 16F819 ICSP programming
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 31st October 2004, 11:15
