Problem using Else
Results 1 to 40 of 47
    Here is the entire code with the WHILE WEND example I was trying to use for a debounce.
    Please ignore what should be upper case because when I copy and paste it changes back to lower case.
    INCLUDE "MODEDEFS.BAS"
    @ DEVICE PIC16F628a,XT_OSC
    @ DEVICE pic16F628a, WDT_OFF
    @ DEVICE pic16F628a, PWRT_ON
    @ DEVICE pic16F628a, MCLR_ON
    @ DEVICE pic16F628a, BOD_ON
    @ DEVICE pic16F628a, LVP_OFF
    @ DEVICE pic16F628a, CPD_OFF
    @ DEVICE pic16F628a, PROTECT_OFF
    CMCON=%00000111
    PORTA = 0
    PORTB = 0
    trisa = %00000010
    trisb = %10000000
    mydata1 VAR byte
    mydata2 var byte
    address1 var byte
    address2 var byte
    checksum var byte
    chk_sum var byte
    serpin VAR porta.1
    PAUSE 50
    loop:
    gosub loop1
    CheckSum = (address1 + address2)
    CheckSum = CheckSum + (mydata1 + mydata2)
    IF checksum != chk_sum THEN loop
    IF (mydata1) != (mydata2) THEN loop
    IF (address1) != (address2) THEN loop
    if mydata1=%01010110 then toggle 0
    pause 50
    if mydata1=%01011001 then
    while mydata1=%01011001 ' trying this example for debounce
    pause 50
    wend
    high 1
    low 1
    if mydata1=%01011010 then
    while mydata1=%01011010
    pause 50
    wend
    high 2
    low 2
    if mydata1=%01100101 then
    while mydata1=%01100101
    pause 50
    wend
    high 3
    low 3
    pause 50
    wend
    high 4
    low 4
    if mydata1=%01101001 then toggle 5
    if mydata1=%01101010 then toggle 6
    goto loop
    loop1:
    SERIN serpin,N9600,[254],address1,address2,mydata1,mydata2,chk_sum
    I think you're confused on the correct method of debouncing.
    The object is to check for a switch hit, wait for the bouncing to stop, then check again and see if the same switch is still hit.
    The way you are doing it, you'll catch the bouncing and kick out of your check before you get a chance to check it after the bouncing is over...
    Try this:
    CMCON=%00000111 : PORTA = 0 : PORTB = 0 : trisa = %00000010
    trisb = %10000000 : mydata1 VAR byte : mydata2 var byte : address1 var byte
     address2 var byte : checksum var byte : chk_sum var byte : serpin VAR porta.1
    PAUSE 50
    loop:     gosub loop1 : CheckSum = (address1 + address2) + (mydata1 + mydata2)
    pause 50
    lp1:
    pause 50
    high 1
    low 1
    pause 50
    high 2
    low 2
    pause 50
    high 3
    low 3
    pause 50
    high 4
    low 4
    goto loop
    loop1:
    Quote Originally Posted by tazntex View Post
    That is because you typed it in lower case and MCS changes it for it's use, when you copy it to the clipboard it reveals the truth.
    Please let us see the code you are sending to this program. Are yoy sending from a PC or a PIC?
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
