Problem using Else
Results 1 to 40 of 47
    You know, the idea of this forum is to provide asnwers for peoples questions.
    If you see something helpfull that you can provide, by all means, speak up and point it out.
    Telling someone to re-read their own program over and over, as if (ha ha, I know what's wrong and you don't).
    Does not help.
    I would, and I will, eventually, maybe. The O/P is seeming to have difficulty in realizing that PICs do only what they are programmed to do...nothing more, nothing less, and just because a programmer wants the PIC to do something, doesn't mean it's going to do it, at least not without proper program and logic flow and hardware to back it up. Feeding, fishing, teaching, learning, all that stuff... He'll get it eventually. He's already figured out a few things for himself. It's only a matter of time before a light bulb goes on...
    Ya'll are great, I will go back through this, print it and try to figure it out. Will be back after awhile and let ya'll know what I have or haven't found.
    Thanks again
    INCLUDE "bs2defs.bas"
    @ DEVICE PIC16F628a,XT_OSC
    @ DEVICE pic16F628a, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F628a, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628a, MCLR_ON
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628a, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F628a, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F628a, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE pic16F628a, PROTECT_OFF
    mydata1 VAR byte
    mydata2 var byte
    address1 var byte
    address2 var byte
    checksum var byte
    chk_sum var byte
    serpin VAR porta.1 'serial input pin
    PORTA = 0
    PORTB = 0
    trisa = %00000010
    trisb = %10000000
    CMCON=%00000111
    PAUSE 50 ' settle time
    loop:
    clear 'Do I really need to do this? I tried to make sure everything is back to 0
    gosub loop1 'After button is released on tx mydata1=%00000000
    CheckSum = (address1 + address2) 'address sent %00000001 added together in this case this = 10
    CheckSum = CheckSum + (mydata1 + mydata2) '10 + (%00000000 +%00000000)= 10
    IF checksum != chk_sum THEN loop 'checksum = chk_sum because of above
    IF (mydata1) != (mydata2) THEN loop '(mydata1) = (mydata2)
    IF (address1) != (address2) THEN loop '(address1) != (address2)
    'Since everything should be a match We move on
    if mydata1=%01010110 then rly1 'this works so I will go to the next one
    if mydata1=%01011001 then rly2 '1st case will turn portb.1 on
    if mydata1=%00000000 then rly2 '2nd case appears to do nothing but as I stated above the check
    'should be correct and mydata1=%00000000
    if mydata1=%01011010 then rly3 'I will skip the rest of this area because it
    if mydata1=%00000000 then rly3 'behaves the same as rly2 the rly6 rly7 ok.
    if mydata1=%01100101 then rly4
    if mydata1=%00000000 then rly4
    if mydata1=%01100110 then rly5
    if mydata1=%00000000 then rly5
    if mydata1=%01101001 then rly6
    if mydata1=%01101010 then rly7
    rly1:
    if mydata1=%01010110 then pause 10
    if mydata1=%01010110 then toggle 0
    pause 10
    goto loop
    rly2:
    if mydata1=%01011001 then pause 10 'Down here the fun begins
    if mydata1=%01011001 then high 1 '1st case will turn portb.1 on
    if mydata1=%00000000 then low 1 'Since the checksum is correct why didn't I get here
    'mydata1=%00000000 so this should go low but doesn't
    goto loop 'here we go back to loop so I will goto loop1
    rly3:
    if mydata1=%01011010 then pause 10
    if mydata1=%01011010 then high 2
    if mydata1=%00000000 then low 2
    goto loop
    rly4:
    if mydata1=%01100101 then pause 10
    if mydata1=%01100101 then high 3
    if mydata1=%00000000 then low 3
    goto loop
    rly5:
    if mydata1=%01100110 then high 4
    if mydata1=%00000000 then low 4
    goto loop
    rly6:
    if mydata1=%01101001 then pause 10
    if mydata1=%01101001 then TOGGLE 5
    pause 10
    goto loop
    rly7:
    if mydata1=%01101010 then pause 10
    if mydata1=%01101010 then TOGGLE 6
    pause 10
    GOTO loop
    loop1:
    SERIN2 serpin,16780,[wait(254),address1,address2,mydata1,mydata2,chk_su m]
    'loop1 receives the following
    'transmit:
    ' serout serpin,N2400,[$55,$55,$55,$55,$55,$AA,$AA,$AA,$AA,$AA,synch,addr ess,address,keydata,keydata,chk_sum]
    ' if keyin = nokey then pause 10
    ' if keyin = nokey then x2
    ' goto findkey
    'x2:
    ' high dgood
    ' keydata = %00000000
    ' goto findkey
    'on the GOSUB loop1 after the tx button is released I should move on to x2
    'x2 sends the preamble, and I am still getting my synch plus address,data an chk_sum
    'so I should pass through the checksum area of my receiver code and on to the rest of
    'my program. When the program arrives at "if mydata1=%00000000 then rly2 " it should
    'ask "if mydata1=%00000000 then low 1" and respond and portb.0 should go low but it
    'never seems to get there. I switch from the If/Then/Else to make it simpler for me
    'to break it down.
    'I've been over the tx side and I feel confident everything there is working correctly
    ' Am I heading in the right direction?
    So between post #34 and #39, that is your entire code for both TX and RX?
    And is it possible for you to connect an LCD to the RX for troubleshooting? Or at least replace those relays with LEDs.
    Skimask here is the entire program for both sides:
    TRANSMITTER
    INCLUDE "MODEDEFS.BAS"
    define osc 4
    CMCON=%00000111
    trisb = %11111111
    trisa = %00010111
    chk_sum var byte
    dgood var porta.2
    serpin var porta.3
    nokey con %11111111
    synch con 254
    address con %00000001
    keyin var portb
    keydata var byte
    E VAR PORTB.0
    D VAR PORTB.1
    G VAR PORTB.2
    A VAR PORTB.3
    B VAR PORTB.4
    C VAR PORTB.5
    F VAR PORTB.6
    na VAR PORTB.7
    PreAmble CON $A5 ' 10100101 preamble
    findkey:
    if keyin != nokey then dout
    goto findkey
    pressed:
    if A= 0 then pause 10
    if A= 0 then keydata = %01010110
    if B = 0 then pause 10
    if B = 0 then keydata = %01011001
    if C = 0 then pause 10
    if C= 0 then keydata = %01011010
    if D = 0 then pause 10
    if D = 0 then keydata = %01100101
    if E = 0 then pause 10
    if E = 0 then keydata = %01100110
    if F = 0 then pause 10
    if F = 0 then keydata = %01101001
    if G = 0 then pause 10
    if G = 0 then keydata = %01101010
    dout:
    gosub pressed
    low dgood
    chk_sum = (address + address)
    chk_sum = chk_sum + (keydata + keydata)
    goto transmit
    transmit:
    goto findkey
    x2:
    high dgood
    keydata = %00000000
    goto findkey
    RECEIVER
    mydata1 VAR byte
    mydata2 var byte
    address1 var byte
    address2 var byte
    checksum var byte
    chk_sum var byte
    serpin VAR porta.1
    PORTA = 0
    PORTB = 0
    trisa = %00000010
    trisb = %10000000
    CMCON=%00000111
    PAUSE 50
    loop:
    clear
    gosub loop1
    rly1:
    pause 10
    goto loop
    rly2:
    goto loop
    rly3:
    goto loop
    rly4:
    goto loop
    rly5:
    goto loop
    rly6:
    pause 10
    goto loop
    rly7:
    pause 10
    GOTO loop
    loop1:
    No LCD, I do have leds and also monitoring the pins with scope.
    thanks
    Quite frankly...what a cluster! You really have to work on your flow. There's too many places where you expect a value to be during one if/then, and then be there again at another if/then even though you just got done changing it.
    Give me a few minutes to work it out...
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
