Debouncing isn't going to work very well without a 'switch' to actually debounce. If you're trying to debounce a received signal, I don't think that it's the right way to go about it.Anyhow, it works, tx side seems to be fine, my big problem is on the rx side each output that is a if/then statement will come on but when I release the button it stays on. The only way to make it turn off is to press another momentary button. The toggle function works fine, although if I hold onto the button to long it will toggle on/off. if/then example I have tried after Skimask post:
This shouldn't be all that hard...but if you continue having problems, you might want to thinking about sending MAKE and BREAK codes with the TX similar to a PC keyboard.
I.E. code1 = button 1 pressed
code2 = button 1 released
code3 = button 2 pressed....
and so on and so on...
