USB PBPL Compile errors
Results 1 to 12 of 12
    Feb 2005
    Essex, UK
    Question Still got this problem...
    I've still got this same problem and I'm just trying to work out if I'm the only person? I know a fair amount of people here are developing code with USB but I'm not sure how many people have upgraded to PBP 2.50. I'm just wondering whether to email Crownhill for support or not?
    Cheers
    Rob
    Quote Originally Posted by Rob View Post
    You'd be better off email'ing MeLabs for help (since Crownhill is a reseller, not the maker), or just hanging out here until Mr.E gets on board.
    Failing that, I'll give it a shot when I get home tonight, or at least sometime this weekend.
    I haven't done any USB compiling lately, but I'll try to duplicate the problem and see what kicks it off...
    Feb 2005
    Essex, UK
    doh - I meant MeLabs - thanks for pointing that out!
    if you get a chance to try it that'd be great! If not though, don't worry as I'm not in any hurry because I can make it compile fine in the USB18 sub-directory and move the compiled files out, it's a bit of a nuisance but at least it works. I'd like to find out what's causing it though; if it's just me or if it's something to do with PBPL.
    Thanks very much
    Rob
    Have you tried copying all of the relavent PBP files over to the project directory and compiling the source from there, instead of the other way 'round (i.e. what you're doing now but the other way 'round in reverse vice-versa upside-down inverted * -1 )?
    Feb 2005
    Essex, UK
    I've got all the files listed in the USB18.txt in the project subdirectory: USB18.ASM, USB18MEM.ASM, USB18.INC, USBDESC.ASM and the project descriptor file and also the 18F4550.BAS file - see attached screen print. This configuration compiles with PBP 2.50a and previous versions, but not with PBPL.
    Cheers
    Rob
    Seems to miss a 18F4550.BAL file in your list.
    Feb 2005
    Essex, UK
    Thumbs up Sorted!
    Hi Mister_E,
    that would be what the problem is then!!!
    These files were generated by EasyHID but EasyHID was developed before PBPL came out and therefore it doesn't produce the ".bal" file.
    Thanks very much for your help
    Rob
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  4. USB compile problem
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2008, 16:39
  5. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 18:13
