I already had those files in my subdirectory. I have now replaced them with the files from PBP2.50 as they seem to be newer versions (I have kept copies of the old ones that were in the subdirectory just in case). Compiling with PBPL gives the same errors but without PBPL is still fine (although the generated code is now a couple of hundred bytes bigger).
Do you not get this problem?
Cheers
Rob
