problem with sending data using RF module
Results 1 to 40 of 52
    See pics in POST#1. 16F877A, and seems ADCON1 and CMCON settings are right.
    Once the wire connection will work, i may suspect 2 other things.
    1)open collector output of the receiver
    2)use inverted mode instead. so the pin will idle low.
    877A
    Well that is what happens when you do not look at the attachments.
    But on the transmitter part I still do not see ADCON1 = 7.
    And on the receiver part I do not see CMCON = 7.
    And in the schematic pin 3 of the LCD goes straight to ground. No pot for contrast. I know on some modules this works, but are you sure it is this time.
    not much help.
    woopseee ... just saw that missing ADCON1
    but in theory... analog comparator are already disabled at POR...
    Dec 2005
    As drawn, both Reset switches are shorting +5V to GND.
    Can you provide details for your transmitter and receiver module manufactiurer/model/pinouts?
    See http://davehouston.org/RFTipsTricks.htm
    Hello rano_zen06,
    Looking at your code . . . not however, trying it out . . . Is this all of it? I do not see anything to cause the transmitter to send data from the keypad, unless I have become legally blind . . . or stupid . . . that is why I asked is this all of it. As I said . . I see empty variables in the serout routine.
     SEROUT TransmitterPIN,T2400,[Synk,Synk,9,Counter]
    I would try adding a string to the serout routine for test purposes only, something like
    SEROUT TransmitterPIN,T2400,$FE,1,["1 2 3 "]
    Joe, seems you missed the underlined section...
    HIGH LEDPin
    PAUSE 100
    LOW LEDPin
    PAUSE 100
    SEROUT TransmitterPIN,T9600,[Synk,Synk,Synk,Synk,Synk,Synk,9,Counter]
    HIGH LEDPin
    PAUSE 100
    LOW LEDPin
    PAUSE 100
    Counter = Counter + 1
    PAUSE 600
    GOTO Main
    Maybe Joe has bifocals like me
    Mar 2008
    Sorry for late reply guys,got a lot of homeworks to do. ; )
    The fact is I have less information about my RF module.I just buy it from the nearest electronic store.Since I live here in Chiang Mai ,Thailand...It's hard for me to find a good types of RF module such as PArallax or TWS/RWS 434...For your reference I attach the picture of the RF modules .The link below may help. It was the datasheet of receiver chip used in my RF module.
    http://www.himark.com.tw/images/pdf/...df/RX3310A.zip
    Hello rano_zen06,
    Actually what I want to do right now is display the counting numbers on my LCD at receiver board and it's nothing to do with my keypad.I just want to try send a data using my RF module first before I proceed with sending the data from my scanning keypad because I need to know if my RF module able to do it's job or not.
    I already connect the Transmitter and the receiver pin directly but it's not work.my LCD only shows a bunch of black box .Maybe the major problem is from my coding or hardware??
    Any other suggestion mister_e ? and how to use inverted mode??
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
