Communicate with PC at baud rate :115200 bps
Results 1 to 15 of 15
    ok what is the suitable PIC IC needed with crystal to achive this problem
    Quote Originally Posted by iugmoh View Post
    FASTER...that's all...FASTER! Read the Tables and you'll see what I mean.
    A serial link can tolerate X amount of error. So, find the combination of oscillator speeds and serial communication speeds that works for your unique situation.
    I can't help you much more than that...I don't think anybody can...until you do some reading and comprehending the information involved.
    The 16F877A will run at 20Mhz (possibly a bit faster), the 18Fxxxx series will run at 40Mhz (55Mhz in my experience, but not recommended for reliability). Either of those chips that you have been relating to in your threads will work just fine.
    You need more crystals! More oscillators! More freq! More cycles per second! More HERTZ! More variances of direct current per unit of time!
    That's all!
    Last Post: - 8th March 2010, 21:58
  2. pic18f4520 baud rate change to 115200
    By caltex88 in forum mel PIC BASIC Pro
    Last Post: - 30th September 2007, 09:41
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
