Auto Baud Rate Detection
Results 1 to 11 of 11
    mytekcontrols's Avatar
    mytekcontrols Guest
    Lightbulb Auto Baud Rate Detection
    The Problem: How can you automatically detect and set the hardware USART to match the incoming baudrate of an external source?
    In the example below you will find my initial solution written entirely in PBP. It requires only one character be sent for synchronization (I chose the ascii space character as my baud rate detect character).
    ' USART Auto Baud Rate Detection
    ' Author:   Michael St. Pierre
    ' Date:     10/25/2005
    ' Notes:    Based on Eddy Carroll article,
    '           April 1989
    DEFINE LOADER_USED 1    ' use for Boot Loader
    DEFINE OSC 40
    ' Equates (for PIC18F252 or PIC18F452)
    baudset var bit
    rxdata var byte
        Clear
    RCIF    VAR PIR1.5      ' USART receive interrupt flag
    BRGH    VAR TXSTA.2     ' High Baud Rate Select bit
    OERR    VAR RCSTA.1     ' Overrun Error bit
    CREN    VAR RCSTA.4     ' Continuous Receive Enable bit
    ' Initialize USART
    ' Set-up USART for initial 19.2K Baud Operation for 40 Mhz oscillator
        SPBRG = 129
        TXSTA = %00100100
        RCSTA = %10010000
    ' Program Start (MAIN)
    mainloop:
        While RCIF = 0: Wend    ; loop until data present in USART buffer
        rxdata = RCREG          ; retrieve data.
        If baudset = 0 Then     ; If this is the initial pass...
        Gosub Autobaud          ; detect and set baudrate,
        baudset = 1             ; deactivate Auto-Baud Rate Detection,
        Goto mainloop           ; and skip data send.
        Endif
        TXREG = rxdata          ; Send valid data bytes only!
        Goto mainloop
    ' Auto Baud Rate Detection Routine
    ' (Entry Baud Rate set to 19.2K)
    ; A single space " " character required for auto detect function
    ; !!! No other characters should be sent prior to space !!!
    ; Format of data upon reception of space " " character:
    ; 4800 baud:  0 128 (2 bytes)
    ; 9600 baud:  0 248 (2 bytes)
    ; 19.2k baud: 32
    ; 38.4k baud: 244 or 252 (slight amount of uncertainty in data)
    Autobaud:
        If rxdata = 0 Then          ; If 1st byte received = 0 then...
        While RCIF = 0: Wend        ; Loop until 2nd valid byte received,
        rxdata = RCREG              ; and fetch data.
        Endif
        Select Case rxdata
        Case 128        ; @4800 Baud (2nd of two data bytes received)
        BRGH = 0
        SPBRG = 129
        Case 248        ; @9600 Baud (2nd of two data bytes received)
        BRGH = 0
        SPBRG = 64
        Case 32         ; @19.2K Baud (1st and only data byte received)
        BRGH = 1
        SPBRG = 129
        Case Else       ; @38.4K Baud (1st and only data byte received)
        BRGH = 1
        SPBRG = 64
        End Select
        If OERR Then    ; If receive buffer overflowed, clear it!
            CREN = 0
            CREN = 1
        Endif
        Return          ; Done, baud rate now set!
    The original idea for this came from an article written by Eddy Carroll www.iol.ie/~ecarroll/autobaud.html in April of 1989. The idea of which was, that a given character would be interpreted in unique bit patterns if sent at different baud rates, and assuming the receiver was set to a "fixed" baud rate.
    In my example, I have enabled 4 different baud rate frequencies to be detected (4800, 9600, 19.2K, 38.4K). These just happened to be the 4 that would properly work with an oscillator freq = 40 Mhz, without producing excessive bit errors. Other ranges can be used, but will require a crystal change, and different SPBRG and BRGH settings, and possibly different comparison strings based on the incoming data.
    Any ideas on how to impove it?
    Another solution is to use any PIC with an EUSART - Enhanced USART - (example 18F2525, 18F2620 etc). The EUSART has Automatic Baudrate Detection capability.
    mytekcontrols Guest
    Thumbs up
    Yes I would totally agree that this would be the best option as a hardware solution. And certainly would be the way to go, especially considering the additional RAM, Flash Memory, and EEprom capacities that come with it. Also for only about $1.00 more than the 18F252 (in quantities of 25 pieces from Digi-Key), it certainly is a bargain.
    However, please bear in mind that although I have used an 18F252 as my text model, the software only approach to Auto-Baud detection can be applied to any PIC having the standard USART. For some this may be the way to go, especially with a large inventory of chips on hand, or where using an alternative less capable chip makes sense from a monentary standpoint.
    Melanie I do have a question to ask of you on the 18F2525/18F2620 chips about some rumors floating around about some quirky issues with this family. I have not worked with this chip myself, and am wondering if any of the rumors are, or were true, but now corrected?
    As always, thanks for your great insights and freely given experience,
    I don't like being the first kid on the block with any new technology. I've seen many people get burned. Two years ago there were too many issues with 18F's altogether. Corporate Management was pushing me on getting a lead time to market of sub-one month and the slightest chance of products not working was not an option.
    Today, the Compilers and Assemblers work as they should, I have a thousand pieces of varous types working in the field without fault and am pretty happy all round. For example, I've replaced a 16F876, 24LC32 and Resonator with a single 18F2420 (without changing the PCB at all), and in process saved inventory, speeded up manufacture and significantly improved profitability of a popular board. No complaints.
    I've not needed the capacity of a 18F2620, I have none actually in the field as yet so I can't comment on it. 18F2420 and 2520... no issues. I'm certainly not going to avoid the part if I need it.
    Personally I think many problems are down to user application design flaws, poor PCB layout, or just picking the wrong part for the job.
    I agree with that too. Poor supply filtering, poor component placement, poor PCB design, unsufficient ground plane, poor noise supression, floating I/O... are common problems. ONE thing, 18F are much noise sensitive than the 16F... WORST when you use 18LF. just be sure you're using the common sense when you design your PCB. I prefer to use external resistor instead of internal for a final design. Internal one are just 'virtual' IMHO.
    Have we already talk about capacitor close to each and every ICs??? Tantalum and ceramic are the one i use.
    mytekcontrols Guest
    All good points, but it appears that some of the rumors are not just rumors. Here is a very recent erratta sheet issued by Microchip on these particular series of chips and the problems that have been due to as manufactured mistakes, and not due to inappropriate usage http://ww1.microchip.com/downloads/e...Doc/80224b.pdf
    I am assuming that the problems as listed in this publication have been corrected in the new silcon coming off the production lines. So hopefully nothing new has crept in after the changes. Of course depending upon how the chips have been utilized in a particular project, these problems may have never been an issue.
    Apparently the topic of this particular post "Auto Baud Rate Detection" was one of the areas where the chip's EUSARTS have had reliability problems.
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 21:58
  2. AUTO baud rate detection FOR UART connection to PC
    By mike20200 in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2007, 01:56
  3. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  4. Automatic Baud Rate Detection
    By titanvision in forum Off Topic
    Last Post: - 4th August 2005, 04:43
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
