Microchip Code Issues
Results 1 to 5 of 5
    Mar 2008
    Default Microchip Code Issues
    Hello, I have been working on the PKE system offered by microchip, I built the circuit and I went to build the source code offered by microchip and when it compiled it in MPlab the base station gave me 40 errors and the transponder gave me 5 errors, I don't have a lot of experience with this code and I just had expected it to work as it, I was hoping that someone could try building it in their compiler and see if it works and if it does just save me the hex files so I can write to my PIC's if this is a possibility please let me know
    thanks
    code is found here:
    http://www.microchip.com/stellent/id...serText=AN1024
    When the zip file from microchip is unpacked, in the subdirectories "output" there are hex files.
    Have you tried those?
    Mar 2008
    Default thanks for the reply Mackrackit
    I hadn't noticed that those were there, do you think that would be the compiled project .hex file? I mean I don't see what else it could be I just didn't think that would be provided, thank you very much for noticing that I will try that today
    I do not know if they are complete or not. Would be worth a try.
    I did try to build the project but ran into problems myself in generating a hex. Not sure why.
    Let us know how it goes.
    Mar 2008
    Default thanks again
    I am just on my way to the lab this morning, I am going to attempt to program this code into the PICs in my circuit I will post back later and let you know if that .hex file was complete.
    thanks again Dave
    Mike
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Microchip MCP41xxx Digital Potentiometer Code Trouble
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 18:21
