Performing a loop every 10ms
Results 1 to 40 of 41
    Lightbulb
    Hi, Wassup
    As Timer 0 is a 8 bits timer ... and we suppose clock is 4Mhz ( ... )
    I will be necessary to have a counting loop in the interrupt stub , because interrupts will occur every 256 µs as a maximum
    The other solution is to use Timer 1 that has a 16 bits counting range ... and won't need any calculations.
    Have a SEARCH for "PicMultiCalc" from Mr E. it's a nice tool to help for Timer designs ...
    Jan 2006
    Istanbul
    ...256 µs as a maximum
    Minimum?
    Maximum?
    I must be on the other side of the mirror.
    Quote Originally Posted by sayzer View Post
    Minimum?
    Maximum?
    The other side of the Bosphor, certainly !!!
    1x 1µs = 1µs ... 256x 1µs = 256µs ...
    so, the maximum period is 256 µs ...
    what was requested for, is a period duration of 10 ms ... or a 10,000 timer count !
    Tell me if I'm wrong !!!
    Jan 2006
    Istanbul
    Depends on what side you are standing at.
    The "maximum" means fastest then.
    Also, what do we get from TMR0 at 4Mhz at 1:4 prescaler ?
    I get roughly 1.03ms.
    I may be doing a wrong math here.
    Feb 2008
    Default Thankyou
    Wow, thankyou for all of your replies.
    I forgot to mention that my crystal is 20MHz and both CCP1 and CCP2 are being used for HPWM.
    I found PicMultiCalc and it is saying that I can use the 8-bit timer (Timer0) for an error of 0.371%. It says that if I use the 16-bit timer I will get an error of 0%. Now I have decided that I will use the 16-bit timer only if it won't interupt my HPWM. The HPWM is driving two motors. I am not at all familure with these timers and I don't know how to set them up or know when to start my 10ms loop so that the gyro can be read at the start of every loop at 100Hz (10ms intervals). Integration calculations and other processes are carried out after the gyro has been read. If all calculations and procesess have been done before the next loop should start, the processor should wait until the timer flag or whatever signals the loop to start over.
    FYI I am making a balancing robot.
    Quote Originally Posted by wasssup1990 View Post
    Said it before, I'll say it again...
    Start simple...
    Get the LED blinking at a known rate under an interrupt drive (or just get an LED blinking ), get the HPWM working on all channels in all situations, get the interfaces working, THEN tie them all together.
    Otherwise you'll be shooting yourself in the foot wondering why...no more...just wondering WHY!!!!
    Feb 2008
    Smile
    Well ok; so it's just a trial and error thing then? I'll just experiment with the PICMULTICALC values by plugging them into the right registers and i'll see how I go. BTW I have no idea of how to use an interupt. Anyhelp in using interupts in PBP relating to what I need will be very much appriciated.
    I was hoping someone here has done what I want done before. Or perhaps someone could link me somewhere, but thanks for all of your help.
    Talking
    You should browse the parallax site ...
    They already did it ( and they share it !!! ) ... and moreover their basic is PbP compatible !!!
    ... at least TONS of understandable solutions to your headaches ...
    Feb 2008
    I saw that balancing robot on the paralax website. It doesn't use a gyro and an accelerometer. Useless on a sloped surface.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  2. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 03:56
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  4. newbie Q - edge detection?
    By RMCRAVEN in forum mel PIC BASIC Pro
    Last Post: - 9th October 2006, 08:20
  5. Newbie question:
    By Izone in forum mel PIC BASIC
    Last Post: - 26th February 2006, 16:24
