Retrieving 32bit Multiply Result
Results 1 to 40 of 43
    Arrow
    And here's the other side of the coin.
    Suppose you want to put a 32 bit number in the PBP system vars where it can be used by DIV32.
    But you don't want to have to multiply two numbers together to get it.
    This allows you to enter a constant, up to 2,147,483,648 which can then be used by DIV32.
    W1   var  word
    PutMulResult macro Const32
        MOVE?CB   low Const32, R2
        MOVE?CB   low (Const32 >> 8), R2 + 1
        MOVE?CB   low (Const32 >> 16), R0
        MOVE?CB   low (Const32 >> 24), R0 + 1
    @ PutMulResult 1000000   ; Load PBP internal vars  -  Max= 2,147,483,648
    W1 = DIV32 300           ; Divide 1000000/300
    '  W1 will now contain 3333
    @ PutMulResult 10562010
    W1 = DiV32 1000        ; Divide 10562010/1000
    '  W1 is now 10562
    -OR-
    If the number is contained in a 2 word variable. You can load the "MUL result" like this...
    Asm
    PutMulResult?D macro Din
        MOVE?BB   Din, R2
        MOVE?BB   Din + 1 , R2 + 1
        MOVE?BB   Din + 2, R0
        MOVE?BB   Din + 3, R0 + 1
        RST?RP
    EndAsm
    DWord  VAR  WORD[2]  ; holds a 31-bit value
    @ PutMulResult?D _DWord   ; Load PBP internal vars  -  Max= 2,147,483,648
    W1 = DIV32 10000           ; 31-bit value / 10,000
    The possibilties, are endless
    HTH,
    Darrel Taylor
    kasapo's Avatar
    kasapo Guest
    Question Math problem
    Hi darel,
    i have a motor control application. in my application pic 16f877 is reading 2 position and then take the ratio of these values and multiply with the constant velocity. for example
    x=5 y=10 then Vy = Vc (constan velocity) , Vx = Vc*x/y
    so two motor begin and stop at the same time. i wrote some code by using Div32 but sometimes i cannot get the values thet it must be.
    // for Trial i give posy greater than posx
    POSX VAR WORD
    POSX1 VAR POSX.BYTE1
    POSX0 VAR POSX.BYTE0
    POSY VAR WORD
    POSY1 VAR POSY.BYTE1
    POSY0 VAR POSY.BYTE0
    V VAR WORD
    V0 VAR V.BYTE0
    V1 VAR V.BYTE1
    HV VAR WORD
    HV0 VAR HV.BYTE0
    HV1 VAR HV.BYTE1
    A VAR WORD
    A0 VAR A.BYTE0
    A1 VAR A.BYTE1
    C VAR WORD
    C1 VAR C.BYTE1
    C0 VAR C.BYTE0
    DUMMY VAR WORD
    Asm
    MOVE?CB Low Const32, R2
    MOVE?CB Low (Const32 >> 8), R2 + 1
    MOVE?CB Low (Const32 >> 16), R0
    MOVE?CB Low (Const32 >> 24), R0 + 1
    EndAsm
    GoSub USBREAD
    POSX1=HB
    POSX0=LB
    GoSub USBREAD
    POSY1=HB
    POSY0=LB
    IF POSY > 6554 Then
    DUMMY = POSY * 10 // i scale posy by 10
    C= Div32 POSX
    @ PutMulResult 2236920 // i also enter here the scaled c constant velocity by 10
    V= Div32 C
    HV = 34 / C
    Else
    DUMMY = POSY * 10
    C = DUMMY / POSX
    V= Div32 C // when this is greter than 16 bits it returns ffff
    HV = 34 / C
    EndIF
    how can i get the V when it is greater than 16 bit ?
    thanks
    There's no way to do that with DIV32. The Quotient must be less than 65535.
    You would need a TRUE 32 bit divide routine.
    Or you could use the Floating Point Math routines from melabs.
    http://www.melabs.com/resources/fp.htm
    Darrel
    kasapo's Avatar
    kasapo Guest
    Question
    hi darrel ,
    do you have some example about the usage of floating point numbers.
    after i do my multiplication and division how can i use aint variable?
    i have to send the aint to my motor controller byte by byte.
    thanks
    mytekcontrols's Avatar
    mytekcontrols Guest
    Question Any way to use a variable for DIV32 divisor?
    Hi Darrel,
    I like your ideas about getting at DIV32 system variables, but I have a slightly different situation. How do I use a variable for the divisor that wont violate the 15 bit rule?
    I tried the following example, but it don't work (I get: Error Bad expression):
    divisor var word
    dummy var word
    dummy = DIV32 divisor
    I really need the ability to alter the divisor via program control, and at times it will need to be bigger then an 8-Bit value. Any ideas?
    Edit: Opps! my mistake. It does work properly with a word variable as the divisor, just so long as you stay with the 15 bit rule (32767). This is good news.
    hehe,
    Default Adding 2 Dwords
    I just saw this link. it is of great interest to me right now...
    I have this question... how do you add two of these Dwords?
    how do i know if the add of two words overflows?
    i.e. $1FFFE + $2E
    my guess is to add the lower words $FFFE+$2E. But how do i know if there is an overflow? so that i can add one to the higher WORD? even worse..
    i.e. $EFFF8 + $6FFE4
    My guess again: add two lower words... if over flow add two higher words +1, else add two higher words....
    I think i can manage myself once i am sure abour the overflow
  1. Strugling without floating point
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 27th March 2011, 07:29
  2. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 15:45
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 08:23
  4. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 15:21
  5. Retrieving Div32 Remainder
    Last Post: - 20th August 2003, 04:53
