Retrieving 32bit Multiply Result
Results 1 to 40 of 43
    Hi Darrel,
    Sorry for the delay. I had some hardware problems which I had to fix.
    Also I’m using a USB to serial interface to communicate with HT and every now and then Windows will see my device as a mouse.
    Here is what I have so far:
    I am able to count down and send out the big_number. I made few changes to your code to format the output as a 8 digit number (kept the leading zeros).
    I’m also receiving the big_number as two 4 digit decimal numbers.
    The only thing left is to make one big_number from the two word size variable (in_high and in_low).
    I was thinking to use your PutMultResult?D macro Din but I’m not quite sure how to do it.
    Here is the latest working code:
    INCLUDE "modedefs.bas"
    @ device pic16F876a,hs_osc,pwrt_on, protect_on
    DEFINE OSC 16
    DEFINE LOADER_USED 1
    DEFIne HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 4800
    define HSER_CLROERR 1
    HighDigits VAR WORD
    LowDigits VAR WORD
    big_number VAR WORD[2] ; 32-bit variable
    in_low var word
    in_high var word
    led var PORTA.2
    ADCON1=6
    CMCON=7
    MOVE?CN macro Cin, Nout
    MOVE?CW Cin & 0xFFFF, Nout ; Low Word
    MOVE?CW (Cin >> 16), Nout + 2 ; High Word
    PutMulResult?N macro Nin
    MOVE?WW Nin, R2
    MOVE?WW Nin + 2, R0
    pause 10000 ' Allow for the USB device to enumerate
    hserout [13,10,"Waiting for Big_number",13,10] ' Add time out later
    hserin [dec4 in_high,dec4 in_low]
    @ MOVE?CN 20000, _big_number
    WHILE (big_number[1] > 0) OR (big_number[0] > 0)
    big_number[0] = big_number[0] - 1
    IF big_number[0] = $ffff THEN big_number[1] = big_number[1] - 1
    @ PutMulResult?N _big_number
    GOSUB SendBigNum
    toggle led ' Show if any action
    WEND
    pause 5000
    SendBigNum:
    HighDigits = DIV32 10000
    LowDigits = R2
    'IF (HighDigits > 0) THEN
    HSEROUT [DEC4 HighDigits, DEC4 LowDigits," and ",dec4 in_high,dec4 in_low,13,10]
    'ELSE
    'HSEROUT [DEC4 LowDigits,13,10]
    'ENDIF
    Thanks again for your patience.
    Nick
    BTW: I'm practising to post code the right way.
    Last edited by Nicmus; - 26th January 2008 at 17:02. Reason: Posting code practice
    This one I'm not so sure about. And I don't have anything handy to test it on.
    I'm pretty sure it will work, but not Positive...
    HighDigits = 100   ; Simulating File Length of 1,000,000
    LowDigits  = 0000
    big_number[0] = HighDigits * 10000
    big_number[1] = R0
    big_number[0] = big_number[0] + LowDigits
    IF (big_number[0] < LowDigits) THEN big_number[1] = big_number[1] + 1
    P.S. To put code in a scrolling box that doesn't scrunch it all to the left, use ...
    [code]' --- code goes here ---[/code]
    oops, nevermind. I see you're even using colors in the test area.
    Hi Darrel,
    I’m a bit confused by your last post.
    I’m not sure were to add this code. Also I have the feeling that the big_number[0] and big_number[1] are switched from the way they are in my code.
    Here is the code in “colors” format:
    <font color="#000000"><b>INCLUDE </b><font color="#FF0000">&quot;modedefs.bas&quot;
    </font><font color="#008000">@	device  pic16F876a,hs_osc,pwrt_on, protect_on
    </font><b>DEFINE </b>OSC 16
    <b>DEFINE</b>	LOADER_USED	1
    <b>DEFINE </b>HSER_RCSTA 90h
    <b>DEFINE </b>HSER_TXSTA 20h
    <b>DEFINE </b>HSER_BAUD 4800
    <b>DEFINE </b>HSER_CLROERR 1
    HighDigits  <b>VAR     WORD
    </b>LowDigits   <b>VAR     WORD
    </b>big_number  <b>VAR     WORD</b>[2]   <font color="#000080"><i>; 32-bit varia
    </i></font>in_low      <b>VAR     WORD
    </b>in_high     <b>VAR     WORD
    </b>led         <b>VAR     </b>PORTA.2
    ADCON1=6
    CMCON=7
    <b>ASM
    </b><font color="#008000">MOVE?CN  macro Cin, Nout
        MOVE?CW  Cin &amp; 0xFFFF, Nout     </font><font color="#000080"><i>; Low Word
        </i></font><font color="#008000">MOVE?CW  (Cin &gt;&gt; 16), Nout + 2  </font><font color="#000080"><i>; High Word
      </i></font><font color="#008000">endm
    </font><b>ENDASM
    </b><font color="#008000">PutMulResult?N  macro Nin
        MOVE?WW  Nin, R2
        MOVE?WW  Nin + 2, R0
    </font><b>ENDASM
        PAUSE </b>1000
        <b>HSEROUT </b>[13,10,<font color="#FF0000">&quot;Waiting for Big_number&quot;</font>,13,10]
        <b>HSERIN </b>[<b>DEC4 </b>in_high,<b>DEC4 </b>in_low]
    <font color="#008000">@   MOVE?CN  20000, _big_number
    </font><b>WHILE </b>(big_number[1] &gt; 0) <b>OR </b>(big_number[0] &gt; 0)
        <b>IF </b>big_number[0] = $ffff <b>THEN </b>big_number[1] = big_number[1] - 1
    <font color="#008000">@   PutMulResult?N  _big_number
        </font><b>GOSUB </b>SendBigNum
        <b>TOGGLE </b>led
    <b>WEND
        PAUSE </b>5000
        <b>GOTO </b>main
    SendBigNum:
        HighDigits = <b>DIV32 </b>10000
        LowDigits  = R2
        <font color="#000080"><i>'IF (HighDigits &gt; 0) THEN
            </i></font><b>HSEROUT </b>[<b>DEC4 </b>HighDigits, <b>DEC4 </b>LowDigits,<font color="#FF0000">&quot; and &quot;</font>,<b>DEC4 </b>in_high,<b>DEC4 </b>in_low,13,10]
        <font color="#000080"><i>'ELSE
        'ENDIF
    </i></font><b>RETURN
    </b>
    How do I process the in_low and in_high variables to get the big_number before entering the main loop?
    Am I pulling them right as DEC4 or should I do it differently?
    Nick
    Sorry. Should have used your variable names ...
    big_number[0] = in_high * 10000
    big_number[1] = R0
    big_number[0] = big_number[0] + in_low
    IF (big_number[0] < in_low) THEN big_number[1] = big_number[1] + 1
    Just stick it after the HSERIN.
    P.S. Nice "Colors".
    Hi Darrel,
    I added your last lines and had to REM the line:
    @   MOVE?CN  1000000, _big_number
    After that everything works as intended.
    I guess the macro this line was pointing to is no longer needed.
    I will open an other thread with a question on detecting EOF.
    There are no words to thank you enough for your help.
    Best Regards,
    Nick
    Yup, that statement/macro is no longer needed.
    EOF marker for a .txt file is usually 26. That's a byte with the decimal value 26.
    In hex it's 1A, ASCII it's ctrl-Z, whichever way you want to look at it.
    Of course that ruins everything we just did.
    And you're welcome.
    Not really.
    For now what we did will work just fine and buys me time.
    But, and I’m sure you are the same way, if it can be improved, and you know it can, loosing few more hours of sleep doesn’t really matter. It will be a future project as I explained in my new post “Detecting EOF” (I will learn how to insert a link, I promise!)
    It’s just like the CC commercial:
    “The smile on your face after getting it done right…………Priceless “
    Thousands of thanks again.
    Nick
  1. Strugling without floating point
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 27th March 2011, 07:29
  2. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 15:45
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 08:23
  4. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 15:21
  5. Retrieving Div32 Remainder
    Last Post: - 20th August 2003, 04:53
