Yes, it loads 1 million into big_number.
But it's a 32-bit binary number, so you can't just display the high/low WORDs with DEC.
The hex representation of 1 million is F:4240.
Then change each word to Decimal F=15, 4240=16960
So it looks like it starts counting from 1516960
To convert the big_number to a readable decimal output takes a little more work.
Code:HighDigits VAR WORD LowDigits VAR WORD ;---[add this with the other macro's]--------------- ASM PutMulResult?N macro Nin MOVE?WW Nin, R2 MOVE?WW Nin + 2, R0 endm ENDASM ;---[add this to your main loop]-------------------- @ PutMulResult?N _big_number GOSUB SendBigNum ;--------------------------------------------------- SendBigNum: HighDigits = DIV32 10000 LowDigits = R2 IF (HighDigits > 0) THEN HSEROUT [DEC HighDigits, DEC4 LowDigits] ELSE HSEROUT [DEC LowDigits] ENDIF RETURNThat depends on where the new big_number is coming from.How do I insert a new big_number
You said you're reading the file length from the USB device.
What format is it in, what variables are you storing it in.
