Retrieving 32bit Multiply Result
Results 1 to 40 of 43
    For words and bytes, you can detect an overflow by testing if the result is less than what you added.
    Due to trucation of a 16-bit word ...
    $FF00 + $0180 = $0080
    So the result will always be less than either of the values added if an overflow occurs.
    I think i can manage myself once i am sure abour the overflow
    I'm sure you could. But that's just not my way ...
    ;Initialize your hardware first
    A         VAR WORD[2]
    B         VAR WORD[2]
    Result    VAR WORD[2]
    OVRFLOW32 VAR BIT
    ; ===== Load 32bit Constant into DWORD =============================
    MOVE?CD macro C32in, Dout                      ; Max= 4,294,967,296
        MOVE?CB   low C32in, Dout
        MOVE?CB   low (C32in >> 8), Dout + 1
        MOVE?CB   low (C32in >> 16), Dout + 2
        MOVE?CB   low (C32in >> 24), Dout + 3
    @  MOVE?CD  0xEFFF8, _A  ; Load 983,032 into A
    @  MOVE?CD  0x6FFE4, _B  ; Load 458,724 into B
    GOSUB Add32
    LCDOUT  $FE,1,  "A=   ",HEX4 A[1],":",HEX4 A[0]
    LCDOUT  $FE,$C0,"B=   ",HEX4 B[1],":",HEX4 B[0]
    LCDOUT  $FE,$90,"Res= ",HEX4 Result[1],":",HEX4 Result[0]
    LCDOUT  $FE,$D0,"OVRFLOW32 = ", BIN1 OVRFLOW32
    stop
    ; ===== Add 2 32bit variables ======================================
    Add32:
        OVRFLOW32 = 0
        Result[0] = A[0] + B[0]
        IF Result[0] < B[0] then Result[1] = 1
        Result[1] = Result[1] + A[1]
        IF Result[1] < A[1] then OVRFLOW32 = 1
        Result[1] = Result[1] + B[1]
        IF Result[1] < B[1] then OVRFLOW32 = 1
    Which displays ...
    A=   000E:FFF8
    B=   0006:FFE4
    Res= 0015:FFDC
    OVRFLOW32 = 0
    HTH,
    Default Checking for a smaller result
    Checking for a smaller result is a simple trick, thanks,
    right now my code is never suposed to exced the Max= 4,294,967,296
    so i am ignoring the OVRFLOW32 = 0.
    This is the code that i am using
    Bigword   var word [2]
    BigwordL  var BigWord(0)
    BigwordH  var BigWord(1)
    Bigword1  var word [2]
    Bigword1L var BigWord(0)
    Bigword1H var BigWord(1)
    AddTwoBigWords:   'Adds Bigword1 and BigWord2 result in BigWord
       BigWordH = BigWordH + BigWord1H  ;ignoring any overflow
       BigWordL = BigWordL + BigWord1L
       if BigWordL < BigWord1L then
             BigWordH = BigWordH+1          ;ignoring any overflow
    Would this be ok? i made some tests and it seems ok but your experience might see anything wrong here.
    Thumbs up
    Yup,
    Looks great to me.
    Nice reduction.
    Red face Another trick?
    I was so confused about the Multiply operation that i posted here but.... i am now just using ** and * :s sorry
    Smile Divide BigWord by Word
    Well i am really proud of this, i Hope its ok.
    For anyone in need of a Division of a BigWord by some number i found this problem:
    Lets think of a BigWord as considered before ^
    Now you might want to Divide a value stored in tBigWord1 by some other value, in this case (EXAMPLE CODE) the value is stored in factoriva.
    One could use the DIV32 function as proposed by Darrel in this or other post BUT if factoriva is too small the result CAN be higher than a word size FFFF, and the the result is no good.
    For example:
    4:01F5 DIV32 2 the result of DIV32 is
    Result = FFFF, Remainder = 01F7 !! Wrong i guess
    This code is possible just thanks to Darrel`s @ PutMulResult?D MACRO
    MainLoop:
        lcdout $fe,1
        tbigword1H = 4         ' My Dollars Value High Word
        tbigword1L = 501      ' My Dollars value Low Word
        cents = 24              ' My cents value
        GOSUB DIVBIGWORD
        HSEROUT [#FactorIva," ",HEX4 tBigWordH,":", HEX4 tBigWordHL,10,13]
        FactorIva= FactorIva+ 1
        IF FactorIva= 101 THEN
        GOTO MainLoop
    'This SUB receives  tBigWord1(Dword) a value to be divided by
    'FactorIva (word), Result in tBigWord, works for any value of FactorIva
    'and tBigWord1 in their limits.
    DIVBigWord:
        tBigWordH= tBigWord1H / FactorIva
        tBigWord1H = tBigWord1H // FactorIva
        @ PutMulResult?D  _tBigWord1
        tBigWordL = DIV32 FactorIva
        Remainder = R2
    This code in the serial port os The value tBigWord1 Divided for Factors 1 to 100
    Seems to work.
    Factor Result
    2 0002:00FA
    Remember to Add the @ PutMulResult?D MACRO posted by Darrel at the begining of the Code.
    Hello everyone,
    I was wandering if it is possible to implement the extended 32 bit idea to something as simple as for / next loop.
    How will this simple loop look like if I need to deal with more than word size index:
    For index =0 to big_number
    Hserout [record(index),13,10]
    Pause 100
    Next
    Is it possible to have a big_number = 1,000,000 – 2,000,000?
    Thank you for your input.
    Nick
    Quote Originally Posted by Nicmus View Post
    Nick
    It's directly possible if you have the PBP 2.50a upgrade, which supports signed/32 bit LONG variables...
  1. Strugling without floating point
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 27th March 2011, 06:29
  2. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 14:45
  3. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 07:23
  4. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 14:21
  5. Retrieving Div32 Remainder
    Last Post: - 20th August 2003, 03:53
Members who have read this thread : 4
