Hi all,
skimask,
i'm not really sure if the servo moves equally to both sides because it will depend on where the center is.
In my program the center is at pos = 700
The servo never came to the point of hitting it's internal stops and "keeping the motor running" ( if you know what i mean )
I can increase the pos value but the servo stops when reaching pos +- 1300.
I think that the minimum value could be the key here...i mean...the min value is 25...can i go lower than this ( minus ) ???
Jumper,
I did not opened the servo yet.
BrianT,
My servos do not have the center adjustment screw. Were did you see this ? I have never seen this in any of my servos ( hitec, futaba, digital/analog ).
About the pulsout method...i tryed once that but for some reason it didnt worked as well as my code above...will try it again though
