Help with DS18B20 program
Results 1 to 39 of 39
    Oct 2007
    Vancouver, BC, Canada
    Joe,
    maybe I rephrase it.
    The program I have attached compile ok with v2.46 and v2.50, no error. I use pic16f876.
    when compile using version 2.46 of pbp, the program is running ok when downloaded to the chip using bootloader. it displays/transmit the temperature reading to the lcd/terminal ok.
    the problem only when compile using v2.50 of pbp, the program (hex file) downloaded/program to the chip using bootloader, the program cannot run/stop/freeze.
    i commented out the configurations because it is not needed when using bootloader (i think it is ok to do so).
    Quote Originally Posted by KVLV View Post
    Joe,
    Without the config statements your program uses the default config statement located in the .inc file of the same name/number as your chip, in this case 16f876 , and the default is for XT_OSC not HS_OSC, and could account for your program's failure to launch as it is set to run at 20 MHZ, the PIC OSC requires more power to operate at 20 than at 4 and the HS_OSC provides that power.
    JS
    Oct 2007
    thanks Joe, lets me try again. and post if any result.
    I can't understand why the program would work when compiled with 2.46 but not with 2.50. I don't believe the config fuses are the problem as I believe they are not used with a bootloader and are simply not implemented at loading time. Unfortunately though I am running 2.45 myself so I won't be of much more help on this issue.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
