Help with DS18B20 program
Results 1 to 39 of 39
    We had a problem similar to this but with the DS1620. The sensors actually measure the temperature of the circuit board, in your case the breadboard. How close is the voltage regulator to the sensor? Can you move the sensor to the opposite end of the board or remotely mount it? This will give you the most accurate temperature measurement since the thermal pathway is the pins on the part itself and not the plastic piece.
    Nov 2007
    Quote Originally Posted by CocaColaKid View Post
    I'm using one of those cheap $4.00 (400 contacts) breadboards. So, my sensor is probably sitting only 1.5" away and directly across the regulator. I will remount the sensor at the bottom right corner of the breadboard (since my regulator is on the upper left corner) and see what happens. Will post results as soon as I can. Thanks for your comments/suggestions.
    With it being that close I'm quite certain that is the source of your problems. Any little bit of heat and the sensor will find it.
    May 2012
    Default Re: Help with DS18B20 program
    hello dears..
    May anyone helps me to get the code of the ds18b20 on proton ide that will show me the temperature on a graphical lcd?I used this one but it's not working can anyone find the error in this code??
    Device 16F877
    XTAL
    =4
    Declare
    LCD_DTPORT PORTB
    Declare LCD_RSPIN PORTC.7
    Declare
    LCD_RWPIN PORTC.6
    Declare
    LCD_ENPIN PORTC.5
    Declare
    LCD_CS1PIN PORTC.4
    Declare
    LCD_CS2PIN PORTC.3
    Declare
    LCD_TYPE GRAPHIC
    GLCD_CS_INVERT On
    INTERNAL_FONT On
    FONT_ADDR
    =0
    Declare
    ADIN_RES 10
    Declare
    ADIN_TAD 2_FOSC
    Declare
    ADIN_STIME 50
    ADCON1 = %10000000
    TRISA = $ff
    TRISB = $00
    TRISC =%11000000
    TRISD =%11000000
    DelayMS 200
    Dim SPTemperature As Word
    ' scratchpad temperature storage
    Dim Reserved0 As Byte ' scratchpad reserved variable
    Dim Reserved1 As Byte ' scratchpad reserved variable
    Dim Reserved2 As Byte ' scratchpad reserved variable
    Dim Reg_TH As Byte ' scratchpad TH register or User Byte 1
    Dim Reg_TL As Byte ' scratchpad TL register or User Byte 2
    Dim Reg_Config As Byte ' scratchpad configuration register
    Dim CRC As Byte ' scratchpad CRC register
    Dim Temperature As Float ' temperature result
    Symbol DQ = PORTD.1 ' one-wire data pin
    While 1=1
    OWrite DQ, 1, [$CC, $44]
    ' skip ROM search And start temperature conversion
    While ORead DQ, 4 = 0 ' check for still busy converting
    Wend
    OWrite
    DQ, 1, [$CC, $BE] ' skip ROM search And read the temperature
    ORead DQ, 0, [SPTemperature.LowByte, SPTemperature.HighByte, Reg_TH,Reg_TL,Reg_Config,Reserved0,Reserved1,Reser ved2,CRC]
    Temperature = 0.0625 * SPTemperature
    ' convert to degrees C
    Print At 1,1,@Temperature, "C",
    Wend
    Many thanks
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
