Help with DS18B20 program
Results 1 to 39 of 39
    Nov 2007
    If ADCON1 = 15 what are they?
    They are ALL digital, right?
    Yeah - I was just reading about ADCON1 on the datasheet and seems like I should try again with ADCON1=15 at the beginning of my program. That will turn RB4 (which is also AN11) into a digital port (along with all the other A/Ds). My fingers are itching to try this out, but alas I don't have my programmer with me. Can't wait to try it out when I go home. Man, this stuff is addicting!
    Thanks Bruce!
    You're 100% correct. Easy stuff isn't it.?
    It really is..;o}
    Just remember, the data sheet is all you really need beyond the PBP manual. Lookup the
    value you need to place in a peripheral register to configure it to work the way you want
    it to, and BINGO you're off to the races.
    It really is that simple.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
