Resistor Ohm Meter
Results 1 to 40 of 43
    T.Jackson's Avatar
    T.Jackson Guest
    I guess one possible solution would be to have roundup & round down buttons. Pressing these buttons would effectively remove the tolerance from the reading by either adding or subtracting 0.25 to 10% (user selectable) - of the resistor's value. From memory there's about 180 different values in the 5 band 1% range. This is the E? something range (totally forgotten) The more obvious solution would be to database the entire range of resistors. When a reading is taken, the system would basically look for a closest match and display the results. Lot of resistors to catalog though.
    T.Jackson's Avatar
    T.Jackson Guest
    Default Programmable OHM Tester
    <table width="100%" border="0" cellpadding="2">
    <tr>
    <td>
    <img src="http://us1.webpublications.com.au/static/images/articles/i307/30755_3lo.jpg" align="left" border="1">
    </td>
    <td>
    This discussion reminds me of a project that I did sometime ago. There's no microcontroller or anything real fancy in this, but it can give an accurate (go / no go) indication, both audible and visual - for many resistive components. The user simply selects an acceptable maximum level of resistance (below or equal to this level is the pass level for a good component) - then this gizmo just returns the results as valid or invalid via a LED & buzzer.
    However, it's very limited. At the time I just wanted something done real quick and dead cheap. The unit can be built for less than the cost of a bus ticket, but it's range is limited to a few hundred ohms only. Another restriction is that, there's no provision for setting a minimum level of acceptable resistance. It has its place, bet auto electricians love it!
    The published article can be seen here: <a href="http://siliconchip.com.au/cms/A_30755/article.html" target="_blank">Programmable Continuity Probe</a>
    </td>
    </tr>
    </table>
    Oct 2007
    Hi Trent.
    There will have to be a database (array) present to get it working. (use a PIC with a big enough program area)
    Once the tested value is known, it should display ALL the "standard" values where the tested value is between the upper and lower of said "standard" value.
    I guess one possible solution would be to have roundup & round down buttons. Pressing these buttons would effectively remove the tolerance from the reading by either adding or subtracting 0.25 to 10% (user selectable) - of the resistor's value. From memory there's about 180 different values in the 5 band 1% range. This is the E? something range (totally forgotten) Lot of resistors to catalog though.
    Problem is that a 10% may only be 5% off target. If you subtract 10% you wouldnt get the correct value anyway.
    But your post gave me another idea: A rotary selector for the tolerance value to use when the PIC has to figure out what to show. The lower you set the tolerance, the less overlapping there will be.
    You forgot the "E? range"! I didnt even know!
    BTW. What are the standard tolerance ranges?
    I've got 0.05% (grey), 0.1% (violet), 0.25% (blue), 0.5% (green), 1% (brown), 2% (red), 5% (gold) and 10% (silver).
    If that is it, we'll need 3 pins to drive the tolerance rotary selector.
    Rotary selectors are EXPENSIVE, maybe a dipswitch would be less expensive, especially in an environment where you only deal with one specific tolerance.
    All I've ever used is 5% (grey) which sometimes looks like silver.
    I swear I spend more time figuring out what the value of a resistor is than I do soldering the thing into place. Even then I often get it messed up as I simply cant make out the colors properly on some of the small ones.
    Did you know that a 3mm led makes an audible "pop" when it goes?
    All the best,
    Aubrey
    (The more you learn, the more you realise how little you actually know)
    Italy
    Are you a resistors manufacturer?
    From page 3: (THEORY of OPERATION)
    http://www.harris-irt.com/anonymousftp/irtman5012xp.pdf
    The 16F877 Microprocessor based circuit includes a dual limit comparator which compares
    the measured resistance with upper and lower tolerance values entered on front panel thumbwheels.
    Red and green front panel light emitting diodes indicate whether or not the resistance is within tolerance.
    An output relay permits the resistance tester to be converted to a rejection device.
    For “fail-safe” operation the contacts are normally open. The contacts close if the part is
    within tolerance. The Microprocessor based circuit also provides for electronic range switching
    and system control.
    Best regards,
    Luciano
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by TheMadMan View Post
    Yes, that did dawn on me shortly after I posted that. A half-baked thought that didn't have a real world scenario attached to it.
    T.Jackson's Avatar
    T.Jackson Guest
    Default Block Diagram
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2074&stc=1&d=119177155 3" border="1">
    </br>
    If I was going to do a project like this, this is probably the road I'd take.
    </br>
    Italy
    Hi Trent,
    (Maybe one stage of your circuit).
    Resistance measurement with Current Source
    http://www.delabs-circuits.com/cirdi.../del20015.html
    (Click on the link "PDF circuit" and then click on the Acrobat Reader save button).
    Best regards,
    Luciano
    T.Jackson's Avatar
    T.Jackson Guest
    Hi Luciano,
    Have you built & tested that circuit? ... (looks comprehensive at first glance)
    I usually do most of my projects from scratch. But I do get ideas from other people's circuitry. I know that there's a lot of people around that just slap together odds & ends that they find in magazines, from books & on the internet. Some of them even try claiming it as their own. This is one of the reasons why I procrastinate about doing anymore projects for publication.
    Italy
    Hi Trent,
    Here is a circuit which was published in a magazine back in 1994.
    The circuit was connected to the serial port of a PC via a parallel
    to serial interface circuit. A MS-DOS program (see picture) was
    used to display the measured resistance value and show the color
    code of the measured resistor.
    10mA was used for resistors from 1 to 100 ohm.
    1mA was used for resistors from 100 to 1k ohm.
    100µA was used for resistors from 1k to 10k ohm.
    10µA was used for resistors from 10k to 100k ohm.
    1µA was used for resistors from 100k to 1 Mega ohm.
    TS27M2CN datasheet:
    http://www.st.com/stonline/books/pdf/docs/2306.pdf
    LM334 datasheet:
    http://www.national.com/ds/LM/LM134.pdf
    Here is the schematic. (I have added the values).
    (Click to enlarge)
    How the current source is used:
    (Click to enlarge)
    The DOS program:
    (Click to enlarge)
    Best regards,
    Luciano
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. VU Meter
    By Andre_Pretorius in forum General
    Last Post: - 20th May 2009, 17:17
  3. Help...Distance Meter
    By tohu thomson in forum General
    Last Post: - 18th September 2007, 08:07
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. PIC10F206 - What is the LOWEST Power @ Rest or Sleep
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 15:42
